Arno140
Jan 27, 2026 7:30 AM UTC
Figma Make - Unable to publish prototype update - "Something went wrong" error
Hello, I'm reporting a persistent bug in Figma.
Issue: Unable to publish prototype updates via the Preview tab. Error Message: 'Something went wrong, reload and try again' (in red). Start Time: Jan 27, 2026
Troubleshooting steps I've already taken:
  • Refreshed the page;
  • Switched browsers and used Incognito mode;
  • Restarted both the app and the computer;
  • Duplicated the file and attempted to publish (the error happens in the new file as well).
Please let me know if you need any logs.
Pinned Reply By Junko3
Hi there,
Thanks for reporting the publishing error you’re seeing.
A fix has been implemented for issues affecting the publishing of Figma Makes or Sites with code components. You can find more details and the timeline here: https://status.figma.com/
Please fully refresh Figma and check if things are back to normal.
Thanks again for your patience while we sorted this out.
yutoo
Jan 29, 2026 8:32 AM UTC
the same.I tried all kinds of methods
Hans Christian
Jan 29, 2026 8:44 AM UTC
And the problem is back. Not possible to publish.
yutoo
Jan 29, 2026 8:46 AM UTC
I have been trying to update 😭 since last night
Simon25
Jan 29, 2026 8:50 AM UTC
​@ksn this is not solved
Jan 29, 2026 11:05 AM UTC
Hey everyone, Celine from Figma here, working closely with ​@ksn . Thanks for following up!
We’re currently investigating the root cause of the issue and will share an update as soon as we have more information. Thanks for your patience and understanding while we look into this.
Jan 29, 2026 2:38 PM UTC
Whenever I try to publish a file to the Community, I encounter an error that prevents the file from being published. I’ve attempted multiple files, but the issue persists.
Could you please help me understand why this is happening and assist me in restoring my ability to publish to the Community?
Thanks
MarkObvious
Jan 29, 2026 2:43 PM UTC
I am having the same problem and so is someone else I work with.
The issues modal doesn’t show up anymore and there is nothing in console explaining why it won't publish
Jan 29, 2026 2:46 PM UTC
Same Here although I can Publish with my other account, I do believe maybe my current account is flagged from publishing designs
Tiffany Liang
Jan 29, 2026 2:51 PM UTC
I’m having trouble publishing my file. Everything was working fine yesterday afternoon, but I’ve been unable to publish since this morning. I’ve already verified that all text layers are using Google Fonts, but the issue persists. Are there any other potential causes or troubleshooting steps I should try?
ksn
Jan 29, 2026 4:22 PM UTC
Hey all (and thank you ​@Celine_) -- wanted to drop another update.
As she mentioned, we are still actively continuing work on it. There was a regression that happened shortly after the original fix. Will continue to update here.
Also, very appreciative of your patience. We know this may be delaying your work, and we’re working hard to get this resolved ASAP.
