Alexandre_MBB
Mar 18, 2026 2:52 AM UTC
Figma Make "Live preview failed" Issue
How to fix the “Live preview failed” issue in Figma Make? I did the troubleshoot and immediate fixes available in the internet like: refreshing the page, duplicating the page, opening in different browsers. It is still working properly on March 13, 2026 but the problem started on March 16, 2026
Celyn_L
Celyn_LSolution
Aug 4, 2026 8:02 AM UTC
Hi ​@韩思麒, thanks for chiming in here. I understand that you're seeing the "Live preview failed" error as well.
For anyone else running into the same issue, we'd recommend trying the following steps first:
  • Revert to an earlier version of the file to see if that restores the preview.
  • Ask the AI to resolve the issue and check whether it's able to recover the file on its own.
If you're still seeing the error after trying those steps, the next best step is to submit a bug report so our team can take a closer look at your specific file.
You can do this by visiting the Support Hub, clicking Start a chat, and typing "Report a bug."
Once you've submitted the report, it would also be really helpful if you could share a link to the affected file and invite support-share@figma.com with Can View access. This won't affect your billing and will allow our Engineering team to reproduce and investigate the issue more effectively.
Thanks!
Celyn_L
Mar 18, 2026 6:46 AM UTC
Hi ​@Alexandre_MBB, Celyn from Figma Community Support here.
Thanks for sharing these details — I understand you’re seeing a “Live preview failed” error in Make since March 16, and I appreciate you outlining the steps you’ve already tried.
I’ve gone ahead and created a support ticket (#1800808) so the team can take a closer look.
When you have a moment, please share the impacted file with support-share@figma.com and grant “Can View” access — this will not impact your billing and will allow us to reproduce the issue and investigate further with Engineering.
The team will follow up with you via the inbox associated with your Figma account. Appreciate your patience while we look into this 🙏
Alexandre_MBB
Mar 19, 2026 4:04 AM UTC
Hi ​@Celyn_L ,
I already shared the file with the said email and grant view access.
Thanks
Alexandre_MBB
Mar 22, 2026 12:28 PM UTC
Hi ​@Celyn_L ,
Can I get any update from this?
Celyn_L
Mar 23, 2026 7:08 AM UTC
Hi ​@Alexandre_MBB, thanks for checking in, and appreciate you sharing the file link and view access with the team.
I can see you haven’t received a response yet — I’ve just nudged the team internally to help move things along. Thanks so much for your patience in the meantime 🙏
Evelyne Cote
Mar 31, 2026 6:04 PM UTC
Any updates on this? I have the same issue… tried everything also…
Alexandre_MBB
Apr 1, 2026 6:36 AM UTC
Saw the Figma support looked up the Figma Make but the issue is still the same. Still waiting for their update/solutions.
Alexandre_MBB
Apr 4, 2026 1:39 PM UTC
Hi ​@Celyn_L , may I get some update from this issue? The problem is still the same and still not yet fixed from my end
Celyn_L
Apr 7, 2026 9:48 AM UTC
Hi ​@Alexandre_MBB ​@Evelyne Cote — thanks for following up here.
Sorry to hear you’re still running into this. Could you try a couple of things to see if they help?
  • Revert to an earlier version of the file to check if that restores the preview
  • Prompt the AI to resolve the issue and see if it’s able to recover the file on its own
@Alexandre_MBB — I also took a look at your ticket (#1800808) and saw the team followed up on March 23. When you have a moment, could you check your inbox and continue the conversation there?
@Evelyne Cote — if the issue is still happening, could you submit a bug report so the team can take a closer look?
You can do that by:
• Going to the Support Hub
• Clicking Start a chat
• Typing “Report a bug”
Once submitted, please also share a direct link to the impacted file, and invite support-share@figma.com and grant “Can View” access. This will not impact your billing and will allow us to reproduce the issue and investigate with Engineering.
Thanks again — appreciate you both taking the time to flag this.
RalphCut
Apr 8, 2026 5:50 PM UTC
I am also experiencing this issue. I did just recently update Figma.
adamsmasher
Apr 8, 2026 6:35 PM UTC
Hey ​@RalphCut! Thanks for your reply.
If you haven’t yet, I recommend trying the steps that ​@Celyn_L mentioned above:
If you have or that doesn’t resolve this for you, then I recommend submitting a bug report so our team can take a closer look at your file in particular. To do that, visit the Support Hub, click on Start a chat, then type “Report a bug”. After submitting, please share a direct link to the file and invite support-share@figma.com with “Can View” access. Note that this will not impact your billing and allows us to reproduce and investigate the issue with Engineering. ‘
If you have any trouble let me know!
