Shane Waters
Jan 24, 2026 4:37 PM UTC
Figma Desktop crashing after reported fix (Make)
The status on Figma Make shows it was fixed late on 1/23, but the Figma Desktop still crashes for me every few requests as of 1/24.  The other annoying part if this helps is it doesn’t retain my last request in the history.  So I make request, it starts to work on it then crashes.  When I reload it doesn’t have my request; I have had to copy the request just incase I have to ask it again.
[Moved by a moderator from “CRITICAL: All ‘Figma Make’ files crashing immediately – React Router Error” to “Figma Desktop crashing after reported fix (Make)” on Jan 24, 2026.]
    Tom Reem
    Jan 24, 2026 11:13 PM UTC
    Hi ​@Shane Waters — thanks for sharing this, and I’m really sorry you’re still running into crashes. I checked on related reports and the internal status of this issue, and it does appear the original problem should now be resolved.
    That said, it sounds like you may be hitting something slightly different. I’ve moved your post into its own thread so we can track this separately and make sure it gets the right attention.
    To help narrow this down, could you share a bit more detail on the following?
    If none of that improves things, let me know and I can help start the process of taking a closer look at the file where this is happening so we can escalate it to our engineering team.
    Appreciate you flagging this and sticking with us while we dig in. 🙏🏻
    Shane Waters
    Jan 25, 2026 1:38 PM UTC
    It shows the reason as “Crashed”.  I will exit out of the app, launch the project again and make 3 or 4 requests which could be 3 or 4 sentence long each and it will simply crash after it thought about the request for 15 to 30 seconds.  I have even tried after it saved, to restart the project, not restart the app, to see if I could prevent the crash and it didn’t solve the issue.  Nothing on myside had changed since the release of the new version of Figma’s Desktop App.
    Shane Waters
    Jan 25, 2026 2:52 PM UTC
    Oh and one other thing to point out.  Not sure if it is a design flaw or symptom, but when I submit a request and it thinks for a few seconds and then crashes, the history shows no request when I launch the project again.  I’m not sure if my request made it thru or it was hung up on my side and that is what causes the crash.  Keep in mind, it could be a request to change a name of a field; like 8 words.
    Tom Reem
    Jan 25, 2026 9:37 PM UTC
    Got it — thanks so much for sharing those details, ​@Shane Waters. That context is really helpful.
    I’ve passed this along to our engineering team so they can take a closer look at what’s happening with the crashes and the missing request history. We’ll follow up as soon as we have more information to share.
    Really appreciate you taking the time to walk through what you’re seeing — it helps us narrow this down.
