Hannes Hauwaert
Drag selection doesnt work in frames anymore
I just updated Figma today, and for some reason. in some frames that I work in I cant Drag select the objects anymore.
None of them are locked and I can still click select them one by one.
in other frames I can sometimes still drag select.
If I rebuild the ‘broke frame’ in a new frame it becomes broken aswell. here is a video of the issue
*Edit*
There is a Huge Section just above these frames, when I zoom out more, I can select again.
when the frame is too close to the section and zoomed in very close. issue happens again
When moving the Fram further away from the frame everything works again
Hannes Hauwaert
*Addition*
It's not possible to drag select anything within a section aswell.
ksn
Hey ​@Hannes Hauwaert - thanks very much for the recording. Very helpful to see how this is surfacing on your end.
Is it possible for you to share edit access to the file you used in your recording? We can have our technical quality team review and see if they can replicate, or find any hidden issues going on.
If you can share, please share that edit access for support-share@figma.com, and let me know the name of file.
Frysing
​@ksn has this been fixed? I am experiencing the exactly same issue.
ksn
Hiya ​@Frysing - I did some searching to see if I could locate any updates (since it’s been a while since the last convo), and I think it would be best to have you write into support for them to review your instance. Can you do the following?
  1. Share edit access to the file(s) you’re seeing this on with support-share@figma.com. You won’t be charged for this, and it will only be viewed for replication purposes by our official support team.
  2. Once you’ve done that, please fill out this form, and include the name of the file(s) you’ve shared.
  3. Reply to me here, and I’ll get that escalated for you.
Thanks!!
JPress
I’m having a similar issue, but in my case some elements can be selected, while others can’t be, or at least can’t be until I’ve dragged my cursor across certain parts of the frame. It seems completely random, and difficult to replicate with any consistency. It even changes depending on where a given frame is on the canvas. My instance is occurring in a project I’m consulting for so I can’t publicly share the screen recordings, but I’d be happy to share anything directly with support.
Sammy Al-Asmar
Also having this exact same issue, very irritating and very random. Trying it in other files and not as prevalent. Any way to fix this without having to create a totally different file in which I am collaborating with different members and cannot transfer feedback/comments etc.?
JPress
It’s probably not even worth the effort of creating a new file. I tried creating a new file with new frames/artboards that I pasted the elements into. It fixed things at first, but as I continued to work in the file, I noticed the issue returning, and differently on each frame even if the frame’s been duplicated and then only slightly iterated on.
Saurabh Nagar
I am facing the same issue, super irritating. Affecting my whole speed by 10x. Please fix this issue asap
Andrea Pronzati
same issue here, it’s driving me crazy..
Saurabh Nagar
Will keep on commenting till this issue is fixed : 7 jun’25
