Hannes Hauwaert
Apr 17, 2025 9:02 AM UTC
Drag selection doesnt work in frames anymore
I just updated Figma today, and for some reason. in some frames that I work in I cant Drag select the objects anymore.
None of them are locked and I can still click select them one by one.
in other frames I can sometimes still drag select.
If I rebuild the ‘broke frame’ in a new frame it becomes broken aswell. here is a video of the issue
*Edit*
There is a Huge Section just above these frames, when I zoom out more, I can select again.
when the frame is too close to the section and zoomed in very close. issue happens again
When moving the Fram further away from the frame everything works again
Holdenhill
Jun 7, 2025 9:06 PM UTC
Same issue. Maybe due to the recent update?
kedosher98
Jun 9, 2025 2:39 PM UTC
Im having a similar issue. I can’t drag to select anything within a section but it works fine for things outside a section
ksn
Jun 9, 2025 3:47 PM UTC
Hey everyone - first, I want to acknowledge that this does seem like an issue that needs to be addressed for each of you. In instances like this (especially when frame behavior comes into play), my recommendation is to file a support ticket. While the same issue is surfacing for others, the causes could be different depending on the structures of your individual designs. Sharing these files can help us see if each of your designs has something in common (that can help narrow down where to start investigating.
I hope this helps give a bit more transparency into why I request that everyone create a support ticket. Here are my instructions how to take further action:
  1. Share edit access to the file(s) you’re seeing this on with support-share@figma.com. You won’t be charged for this, and it will only be viewed for replication purposes by our official support team.
  2. Once you’ve done that, please fill out this form, and include the name of the file(s) you’ve shared.
  3. Reply to me here, and I’ll get that escalated for you.
Again, I appreciate you all continuing to keep this ticket going. I’m going to mark this reply as a highlight, so any newcomers that see this post will see this more easily.
I will also update you if I receive any updates. Thank you!
simgust
Jun 11, 2025 11:41 AM UTC
Just wanted to chime in and say I’m also experiencing this. I don’t have time to file a support ticket or share a file, but here’s a video. Hoping this gets fixed. For me it changes depending on the frame size.
https://imgur.com/a/lk0ugS9
JPress
Jun 11, 2025 2:03 PM UTC
​@ksn The file I’m working in that best demonstrates the issue is for a work project, and I’m sure that’s the case with others as well. How should we share file access for proprietary work? I understand we won’t be charged for sharing with Figma support, but you say the file will be replicated. What happens with the file once the issue is resolved?
Phil_Earnshaw
Jun 11, 2025 3:08 PM UTC
I am having the same issue, however it is limited to one file. I duplicated the file and the duplicate works fine. Very weird. Not ideal if (like me) you have already shared links with a client but I can’t continue working having to individually select layers so this will have to do for now.
EDIT
It turns out it was still intermittently buggy so I had to manually copy everything out to a fresh new document and now it seems fine.
EDIT EDIT
So the fresh document has now regressed and has the same bug as well… this is really annoying!
daydog
Jun 12, 2025 12:20 AM UTC
I’ve been experiencing this issue for the past several days. There’s a large section above the broken frame. As a temporary solution, I found that moving the problematic frame away from this large section helps.
But now, even that doesn’t work anymore.
Jun 12, 2025 6:35 AM UTC
Hi all,
Thanks for your patience. We’ve flagged internally and our engineering team is investigating this issue. We will get back to you when I have anything I can share with you.
Toku
JeremieD
Jun 12, 2025 2:40 PM UTC
Also having this issue. I was noticing it the other day, but it just keeps getting worse and worse.
Andrewww
Jun 12, 2025 5:49 PM UTC
Had the issue today, moved the frame to a different location and it magically worked.
At least it fixed it temporarily.
