fayet
Apr 16, 2026 12:06 PM UTC
Creating a Make Kit- design library not showing up on the list
Hi,
I am trying to create a Make kit and I click Add items on your kit > Libraries and it lists down the libraries available in the organization. However, there are libraries that I need that are not shown on the list even if I search for them.
Are there any settings required on our library files for it to be used in Make kits?
adamsmasher
adamsmasherSolution
Apr 30, 2026 5:36 PM UTC
Thanks for the screenshot, ​@LucasGP! I actually saw that in my own file, too, and was also confused. 😅
I’ve got clarification, though, which should help for everyone in this thread who is having trouble using a library in Make.
  1. We removed the option within Figma Design to use the library in Make - we’ll be updating the help article shortly so it’s up-to-date. To use a library in Figma Make:
    1. Open your Make File and click on the Gear icon on the top right.
    2. Choose Create a kit.
    3. After loading, click on Library Styles on the Create a kit popup.
    4. In the search bar, search for your published library.
    5. Click on the library in the list, then click on Start generating.
  2. If you don’t see your Library listed after searching, make sure of the following with your Library:
    1. Ensure that the library includes at least one style (fill, stroke and text styles) or variable (boolean, float and color variables).
    2. You’ve published the library since adding at least one style or variable.
    3. You library’s sharing permissions are correct so it’s available for whoever is trying to use it to make a kit.
I’m marking this as the solution as it worked for me, but please let me know if you still has trouble!
adamsmasher
Apr 16, 2026 11:20 PM UTC
Thanks for your post, ​@fayet.
Let’s see if we can figure out together why you aren’t seeing some libraries as available for your Make kit.  For every library that you want available for Make, you’ll need to do the following:
  1. In Figma Design, go to the library you want to use in a Make kit.
  2. If you haven't yet, publish the library.
  3. Click the down arrow next to the file name, and then Use library in Make.
For those that are not showing, can you follow the steps above? I imagine that these libraries are published, but they may still need you to click to use them in Make.
Let me know if you have any trouble!
Tyler Crumrine
Apr 18, 2026 2:30 AM UTC
I’m seeing this exact same problem, only 5 of my published libraries are available when setting up a Make Kit. Clicking Use Library in Make just takes me to the screen for creating a Kit but the list of libraries hasn’t updated.
Ashley_Presman
Apr 22, 2026 3:44 PM UTC
I’m seeing the same problem! Not all of our organization’s libraries are showing up.
Gayani_S
Apr 23, 2026 1:26 PM UTC
Hey both, thanks for flagging this!
I’m jumping in to help here on behalf of ​@adamsmasher. Before I loop in our support team, could you try the steps below, which ​@adamsmasher also suggested.
  1. Open the Design library file
  2. Go to Assets, then Libraries, then Publish
  3. After publishing, click Export for Make and allow the export to fully complete
  4. Go back to your Make file, click Select a Library, and check if the library now appears
If it’s still not showing up after that, let me know and I can get a support ticket created so the team can investigate further.
Once we create the ticket, it’d be helpful to share:
  • A link to the design library file you’re exporting
  • A screenshot of the publish modal (showing whether Export for Make is available or any errors)
  • Confirmation that the Make file and library file are in the same organization
  • View access for support-share@figma.com so the team can check the export state on their end
No need to share any of this publicly here on the forum, you can provide it directly in the support ticket.
Another thing you could try in the meantime is duplicating the library, publishing the duplicate, and then importing that into your Make file.
Let me know how it goes, happy to help further!
Hattie Tadsen
Apr 23, 2026 2:14 PM UTC
Running in to this same issue here. Even as owner of the library files, there is no option to Export for Make. Even when this library, prior to the change to Make Kits was exported and used in Figma Make files.
Screenshots for reference. Export from the File Name and Export from the top Figma menu.
There is an option to “Use library in Make” which then just takes me to Figma Make with the libraries dialog open and the library I’m wanting to use is not showing up.
I assume this is where others are also running in to the bug.
Joanne Wong
Apr 24, 2026 12:10 AM UTC
I’m finding that the previous libraries that I had connected to Figma Make are no longer showing up on in the libraries to help me assemble my kit.
However, I don’t know where to find these libraries within Figma Make anymore.
Sam_Marks
Apr 24, 2026 3:26 PM UTC
I had the same problem. The library I wanted to show up that wasn’t did not have any styles defined in it. I defined one color style and republished the library. The next time I checked the libraries dialog the missing library was no longer missing. Hope this helps!
adamsmasher
Apr 26, 2026 6:41 PM UTC
Thanks for sharing that tip, ​@Sam_Marks!
Question for everybody - when was the last time some of these libraries were published? Was it recent or a while back. I’m wondering if this is more of an issue with libraries that haven’t been published recently.
I would also add that if you believe there are already styles in the published library, try making another change to the library so you can publish again. After publishing, you can remove or undo the change and then publish a second time.
If you continue to have trouble after that, we can create a ticket for you like ​@Gayani_S suggested so our team can take a look.
Prasad P
Apr 27, 2026 3:20 AM UTC
Facing the same issue here — the published library isn’t showing in Figma Make while assembling the kit. However, the same file is visible under the Assets section. Also, as mentioned earlier, I’m unable to find the “Export to Figma Make” option.
Hattie Tadsen
Apr 27, 2026 12:57 PM UTC
Thanks ​@Sam_Marks for the workaround to create a style and publish. The library tests I was doing does show up now when trying to select for a Figma Make Kit.
​@adamsmasher - My issues were on libraries that had published changes within the last week and then when duplicating a library to test further it was a brand new publish that was still not available.
Hopefully this information about having at least one style within the library makes it in to some sort of documentation or the requirement gets removed so there aren’t workarounds to make stuff work like it had previously.
