Jeandre
Nov 25, 2025 7:55 AM UTC
Couldn't reach server, try again in a Try again minute
Try again
minute
I am getting this error for the last hour is there anything down on Figma side?
Gayani_S
Apr 24, 2026 10:55 AM UTC
Hey ​@Nidhi Ranpura, I hear you!
As I mentioned in my previous reply, what makes this issue particularly tricky is that the “Couldn’t reach server” error doesn’t come from a single root cause. It can be triggered by a range of factors, in some cases only on Figma’s side. Because of that, there isn’t one universal fix that resolves every instance of this error all at once.
One thing that has helped in some cases is switching the AI model used in Make to see if the issue is model-specific. You can find steps for that here: Select an AI model to use in Figma Make.
If the issue continues even after trying different models, it would really help for the support team to take a closer look at your specific setup. You can reach them directly through our support hub: https://help.figma.com/hc/en-us/requests/new.
Credits are only consumed when Make successfully performs work in response to a prompt. If a request fully fails and no output is generated, credits shouldn’t be deducted. If you believe credits were used incorrectly, the support team can review that with you.
Thanks again for flagging this, and please let me know if you need any help contacting our support team.
