Michael Levin
Couldn't load Make. Try checking your network connection or refreshing the page. (M2)
    Celine_Solution
    Hey ​@CreativeMind ! Celine from the Community Support team at Figma here.
    Thanks for sharing the screenshots. I can see that you've already updated your proxy configuration, but *.makeproxy-c.figma.site is still showing as Blocked in Figma's Network settings. Please try first to force-quit and restart Figma to see if that helps.
    If not, since you've already gone through the recommended network configuration and the issue persists, I'd recommend submitting a bug report so our team can investigate further.
    Please include:
    • The screenshots you've shared here.
    • The operating system you're using.
    • Whether this occurs in the desktop app, browser, or both.
    • Confirmation that you've already updated your proxy configuration and restarted Figma after making the changes.
    You can submit a report through the Support Hub by typing "Report a bug, Contact an agent’, then clicking Start a chat , select Enter and following the prompts.
    Our team will be happy to take a closer look. Thanks for taking the time to provide the details!
    dcampero
    I am having the same issues with both the browser and the desktop app.
    Gayani_S
    Hi both, thanks for reporting this and for confirming that you're seeing the same “Couldn't load Make. Try checking your network connection or refreshing the page. (M2)” message.
    To help us narrow down what might be causing this, could you please check a few things for me?
    • Are you connected through any VPN, proxy, or network security tools ?
    • If possible, could you try switching to a different network or temporarily disabling the VPN/proxy to see if the issue persists?
    • If you're using the browser, could you try disabling any browser extensions to see if that changes the behaviour?
    Can you please try opening these two links and let us know if the pages load showing "OK" on the screen or if they load blank?
    1. https://check-network-compatibility.figma.site/
    2. https://check-network-compatibility.makeproxy-c.figma.site/
      If either of these links load blank, can your IT team please ensure that Figma's domains (listed below) are explicitly allow-listed as described in Adjust your network settings?
      • *.figma.com
      • *.figma.site
      • *.makeproxy-c.figma.site
      • *.makeproxy-m.figma.site
      • *awswaf.com
      • esm.sh
      • jsdelivr.net
    You can also run a quick network diagnostic directly in your Make file:
    1. Click the question mark icon (?) in the bottom-right corner
    2. Select “Check Network Settings”
    This will show whether your network is properly configured or if any domains are being blocked. More details here:https://help.figma.com/hc/en-us/articles/19424714305943-Adjust-your-network-settings
    Thanks again for flagging this and helping us investigate. Once you’ve had a chance to check the steps above, feel free to share what you find and I’ll be happy to continue helping from there.
    Michael Levin
    It works previously with the same company network configuration. The issue is related for .make files only and I am blocked from working on Figma...
    Michael Levin
    Hi, the issue is not solved. Can someone from  support look on it? support-share@figma.com
    Gayani_S
    Hey ​@Michael Levin!
    I’ve gone ahead and created a support ticket for you so the team can properly investigate what’s going on. Your ticket number is #1808580, for reference. They should follow up as soon as possible.
    Appreciate your patience in the meantime!
    Mohamedkhader
    Gayani_S
    Hey ​@Mohamedkhader, thanks for sharing the screenshots!
    The two domains *.figma.site and *.makeproxy-c.figma.site being blocked will likely be what's causing the trouble you’re seeing so you would need to double check your firewall settings/reach out to your ISP/IT Team to check these domains are allowlisted.
    You wouldn't necessarily see these issue in other files as these domains are only used either by Make & sites.
    Our Help Center article “Adjust your network settings”, outlines all the domains that need to be allowlisted for Figma to work properly.
    Hope this helps!
    Renier Van Niekerk
    Has anyone figured out what causes this. I have never had this issue, was working perfectly fine the entire day, and then suddenly this happened...
    Kevin.peter
    i’m having the same issue
    Kevin.peter
    The files were working before, but now i’m getting the same issue… I haven’t changed anything and i’m on my personal desktop… Tried many browser as well but it’s still not resolved
