Natthan
Oct 28, 2025 8:21 PM UTC
"Could not initialize WebGL" on Desktop App (Win 11 ARM / Snapdragon X Elite) following 28/10/2025 Update
Hello Figma Team,
I am encountering a critical issue with the Figma Desktop application (Windows 11 ARM64).
Since today's update, the application displays the error message: "Could not initialize WebGL".
This problem is highly likely related to the GPU/driver detection in the latest version of the app.
My Configuration:
  • OS: Windows 11 ARM64
  • Device: ASUS Vivobook S15 (Snapdragon X Elite)
  • GPU: Qualcomm Adreno X1-85 GPU
  • Adreno Driver Version: 31.0.121.1 (the latest installed via Windows Update).
Diagnostics and Steps Already Taken:
  1. WebGL works perfectly when I use Figma in my browser (Chrome/Edge).
  2. The error occurs only on the Figma Desktop application.
  3. I attempted a clean reinstall of the Figma Desktop app (uninstalled, manually deleted GPUCache and Local Storage folders in %AppData% and %LocalAppData%) without success.
  4. I also tried to force the rendering via the command line with the --use-angle=gl and --ignore-gpu-blacklist flags, but the error persists.
Hypothesis:
It is highly probable that the latest version of your internal Chromium runtime has added my specific graphics driver (31.0.121.1) to a blacklist of unstable GPUs for WebGL on the ARM architecture, thereby preventing initialization.
Could you please confirm if there is a known blocking rule for this driver in the latest Desktop app update for Windows ARM, or if a fix is planned to allow this driver to use OpenGL rendering?
Thank you for your assistance.
djvSolution
Dec 4, 2025 4:47 PM UTC
Hey All, thanks again for your patience while the team worked through this issue!
As ​​​​@Natthan originally suspected, the team confirmed that this is an issue with Snapdragon X Elite drivers from Qualcomm, which is causing WebGL to fail. This is a minimum requirement of Figma, so because of this, the app doesn't launch as expected. The flag is forcing the use of Vulkan, which works as an alternative. To learn more about why this isn't working, you can reach out to Qualcomm directly. The workaround comes from this forum post.
Here are the steps to mitigate this:
  1. Create a shortcut of figma.exe
  2. Open properties of the shortcuts
  3. Add “--enable-features=Vulkan --disable-gpu-compositing” at the end of the target
  4. Apply and launch Figma with the shortcut
Please try this solution and let us know if you run into any further issues.
Oct 30, 2025 10:50 PM UTC
Hi ​@Natthan, thanks for reaching out!
Since this WebGL error seems to be only showing in the desktop app and running as expected when using Figma in the browser, please let me know:
  1. Can you see if the issue persists if you Clear the Figma desktop app cache?
    You can do this from the Help menu selecting Troubleshooting > Reset Figma and Restart
  2. Can you confirm if the same issue occurs if you try connecting to a different network (e.g. mobile hotspot)?
Natthan
NatthanAuthor
Oct 31, 2025 7:26 AM UTC
Hi,
Thanks for your suggestions. I’ve followed the steps you recommended:
  • Cleared the Figma desktop app cache via Help > Troubleshooting > Reset Figma and Restart
  • Tried connecting through a different network
Unfortunately, the WebGL error still persists in the desktop app, while Figma continues to work fine in the browser.
Could it be compatibility issues between snapdragon graphic drivers and the electron version of figma ?
Thanks again for your help,
Natthan
Oct 31, 2025 3:40 PM UTC
Thanks, ​@Natthan!
I’m not familiar with any compatibility issues between snapdragon graphic drivers and the electron version of Figma, but I’ve created ticket #1578057 on your behalf and escalated this issue to our technical quality team to investigate further.
Natthan
NatthanAuthor
Nov 1, 2025 1:27 PM UTC
Thank you !
I look forward for any answers :)
Dandi Feng
Nov 17, 2025 8:03 PM UTC
​@djv Following as I have exactly the same issue.
My specs:
Lenovo Yoga
ARM64
Snapdragon(R) X Elite as well
OpenCL, OpenGL, and Volkan Compatibility Pack is installed.
Attached screenshot for reference of the error.
Dandi Feng
Nov 17, 2025 8:11 PM UTC
Update with more info: the screenshot is for when launching the design file.
Following the dialog box message does not resolve the issue. Still unable to launch design files in desktop app.
Husna Moetiaputri
Nov 20, 2025 10:17 AM UTC
hi ​@djv i have exactly the same issue. i use figma desktop, but always show the pop up “could not initialize WebGL”
Nov 21, 2025 4:54 AM UTC
Hey All, thanks for following up here!
Can you please let us know if you’re using the latest version of the desktop app?
Natthan’s issue was initally resolved after reinstalling the desktop app: https://www.figma.com/downloads/
If that doesn’t work, support suggested trying the Figma Beta app: https://help.figma.com/hc/en-us/articles/5601429983767#Download_the_beta_version
If neither work, are you able to reproduce the issue and share the following with our technical quality support team?
You can file a bug report with this information for the team directly here: https://help.figma.com/hc/en-us/requests/new
Natthan
NatthanAuthor
Nov 21, 2025 1:22 PM UTC
Hi,
I just wanted to say that this bug reappeared yesterday after the latest update. To fix the issue last time, I had to completely reinstall Windows, but I cannot do that every week after your updates.
I will send the debug information to the developer to help find a solution.
PS: figma beta didn’t help ( + there is no arm version of figma Beta ).
Natthan
NatthanAuthor
Nov 21, 2025 1:26 PM UTC
Here is the debug info attached to this message.
Hope the support will be able to help, Figma is so nice to use.
And here is the link to the screen recording video:
