Imtiyaz_Ahmed
Jul 23, 2025 6:59 PM UTC
Connect to a new supabase account
Hey Peeps,
Right now my Figma Make is connected to one of my Supabase account which has two of my projects. But I have created a new Supabase account for newer projects, but Figma Make is not allowing me to disconnect the current integration and login or connect to another supabase account.
Is this a limitation or can this be fixed with the current capabilities and features.
​@Tom Reem Kindly help, ASAP!
Tom Reem
Tom ReemSolution
Jul 29, 2025 1:00 AM UTC
Glad that helped, ​@Imtiyaz_Ahmed — and thank you for your patience and for sharing that context.
I reviewed the example you provided with our product team, and we can confirm that once you’ve set up a Make using Account 1, that Make will continue to have access to Supabase even if you later disconnect Account 1. Hopefully that unblocks you and lets you move forward with your workflow.
Let me know if anything else comes up — happy to take another look!
Imtiyaz_Ahmed
Nov 25, 2025 4:50 AM UTC
First of all, you can disconnect Figma Make and Supabase from Supabase settings and not Figma.
Go to your supabase account. Login and access the project. Go to settings on the left navbar. Find the tab titled “OAuth”. Inside it you shall find list of external apps connected to Supabase. Once you spot Figma there, hit the delete button.
Figma and Supabase should be disconnected successfully. Unfortunately, its not possible from Figma end right now.
Then try reconnecting to your Supabase from Figma by logging in again. Once done you can either connect your existing database or create a new one. Also since your project is deactivated, I suggest you resume it from settings if you wish to continue the use the same project for your Figma Files.
That's the point. I went to my Supabase account and disconnected Figma, but Figma still recognizes that it is connected and suggests creating a new project.
Right now, I'm stuck because I can't create a project or connect a new account.
Cools, this is weird. Atleast, we have the clarity of the problem now.
Have you also tried disconnecting it from Figma? I just checked and apparently there is an option to Disconnect or Manage Organization.
If it does not work through that option too, then its an internal bug. You should report it
