driftingsteps
Components with mouse interactions revert to default variant state, but only when logged in
  • January 13, 2026
  • 22 replies
  • 774 views
My components with "while hovering" and "while pressing" variants (and interactions) are reverting back to the default values and icons when I'm interacting with them. I've tried viewing the prototypes within the Figma desktop app, as well as on Firefox, and on either cases this issue persists.
Weirdly though, this only happens if I'm logged into Figma. If I view the same prototype in Private/Incognito browser window, this issue doesn't occur.
Figma Version: Figma Desktop App version 125.11.6
Operating System: MacOS Tahoe 26.1
Preview:
Best answer by Celine_
Hey everyone, thanks for your patience while our engineering team looked into this.
They investigated the issues reported by ​@Lucy_Hill and ​@Alexandra Vega  (thank you for submitting bug reports!), confirmed this was a bug, and have now released a fix. Please refresh your tabs and try again. Things should be working as expected now.
For others, if you’re still running into issues, please follow these steps so the team can take a closer look:
  • Share edit access to the affected files with support-share@figma.com. This is our official Support account, and only select Support and Engineering teams will be able to access the files for investigation. You won’t be charged for this.
  • Submit a help ticket here and include direct URLs to the files you’ve shared.
    Once that’s done, let me know and I’ll make sure your ticket is escalated for review. Thank you!
Todd_Coleman
I am having a very similar, if not exact, problem.
Lucy_Hill
I am also having this same problem, with nested components only for mouse enter and mouse leave interactions. Also having a similar issue with switching boolean props on/off causing overrides to be reset.
Alexandra Vega
Hello, I am having the exact same problem with while hovering, on click, and boolean interactions, the overrides keep resetting to default and I’ve checked the main component multiple times, it was working perfectly last week…
Kaarel
Hello, I’m experiencing this in all my projects. While the button prototypes work as expected in the library file itself, the interactive components revert to default state while pressed in project file. It seems that on pressed state defined property overrides on the component are not respected/carried over to this state.
Laura Fegan
We are also experiencing this issue with our components
driftingsteps
Did this issue persist on Incognito/Private browser window?
​@Todd_Coleman ​@Lucy_Hill ​@Alexandra Vega ​@Kaarel ​@Laura Fegan
Alexandra Vega
No, on the Incognito window doesn't happen. Only in Chrome regular window when I'm logged in.
Laura Fegan
No, it doesn’t persist on incognito. It also seems to be occurring just with nested components for us.
Lucy_Hill
Yes, on both incognito window and also on the desktop app.
Camilo T.
+1
