Components with mouse interactions revert to default variant state, but only when logged in
  • January 13, 2026
  • 22 replies
  • 635 views
driftingsteps
My components with "while hovering" and "while pressing" variants (and interactions) are reverting back to the default values and icons when I'm interacting with them. I've tried viewing the prototypes within the Figma desktop app, as well as on Firefox, and on either cases this issue persists.
Weirdly though, this only happens if I'm logged into Figma. If I view the same prototype in Private/Incognito browser window, this issue doesn't occur.
Figma Version: Figma Desktop App version 125.11.6
Operating System: MacOS Tahoe 26.1
Preview:
Best answer by Celine_
Hey everyone, thanks for your patience while our engineering team looked into this.
They investigated the issues reported by ​@Lucy_Hill and ​@Alexandra Vega  (thank you for submitting bug reports!), confirmed this was a bug, and have now released a fix. Please refresh your tabs and try again. Things should be working as expected now.
For others, if you’re still running into issues, please follow these steps so the team can take a closer look:
  • Share edit access to the affected files with support-share@figma.com. This is our official Support account, and only select Support and Engineering teams will be able to access the files for investigation. You won’t be charged for this.
  • Submit a help ticket here and include direct URLs to the files you’ve shared.
    Once that’s done, let me know and I’ll make sure your ticket is escalated for review. Thank you!
Todd_Coleman
  • January 13, 2026
I am having a very similar, if not exact, problem.
Lucy_Hill
  • January 13, 2026
I am also having this same problem, with nested components only for mouse enter and mouse leave interactions. Also having a similar issue with switching boolean props on/off causing overrides to be reset.
Alexandra Vega
  • January 13, 2026
Hello, I am having the exact same problem with while hovering, on click, and boolean interactions, the overrides keep resetting to default and I’ve checked the main component multiple times, it was working perfectly last week…
Kaarel
  • January 13, 2026
Hello, I’m experiencing this in all my projects. While the button prototypes work as expected in the library file itself, the interactive components revert to default state while pressed in project file. It seems that on pressed state defined property overrides on the component are not respected/carried over to this state.
Laura Fegan
  • January 13, 2026
We are also experiencing this issue with our components
driftingsteps
  • January 14, 2026
Did this issue persist on Incognito/Private browser window?
@Todd_Coleman ​@Lucy_Hill ​@Alexandra Vega ​@Kaarel ​@Laura Fegan
Alexandra Vega
  • January 14, 2026
No, on the Incognito window doesn't happen. Only in Chrome regular window when I'm logged in.
Laura Fegan
  • January 14, 2026
No, it doesn’t persist on incognito. It also seems to be occurring just with nested components for us.
Lucy_Hill
  • January 14, 2026
Yes, on both incognito window and also on the desktop app.
Camilo T.
  • January 14, 2026
+1
Kaarel
  • January 15, 2026
Any updates on this Figma? This has been ongoing for whole week soon. How do I solve this?
  • January 15, 2026
Hi everyone, Celine from Figma here! Thanks everyone for flagging this and for sharing examples. I can see how disruptive this is, especially since it’s affecting multiple interaction types (hover, press, boolean props) across different files.
The fact that this only happens when you’re logged in (and not in an incognito/private window) is especially helpful context and suggests this will need a deeper investigation to reproduce and understand what’s happening here. In the meantime, could you also check whether the issue occurs in other browsers? Our supported browsers are Chrome 99, Firefox 101, Safari 16, Microsoft Edge 121 or later.
To make sure our support team can properly dig into this, the best next step is to reach out to them directly so they can review the affected files.
You can do that via our Support Hub here:
  1. Go to the Support Hub
  2. Type your question
  3. Click Start Chat, and type ‘Report a bug’ .The chatbot will help you open an email case with our Support team.
Once submitted, the Support team can investigate further and loop in engineering as needed. Thanks again for taking the time to report this,  it really helps us understand the scope of the issue.
Alexandra Vega
  • January 15, 2026
Hello ​@Celine_ , for me it’s like this with the browsers:
  • Figma Desktop app ❌
    v125.10.8  Issue
  • Chrome window ❌
    v143.0.7499.193 - Issue
  • Chrome Ingonito/Private window✅
    v143.0.7499.193 (logged out) - Works fine
  • Microsoft Edge✅
    v143.0.3650.139 (logged out) - Works fine
  • Firefox ✅
    v147.0 (logged out) - Works fine
I have submitted the ticket and waiting for the response, if I manage to solve it I’ll try to post back here.
Thanks for reaching out to us Celine
Lucy_Hill
  • January 19, 2026
Hi ​@Celine_
for me with browsers it’s like this:
  • Chrome window - logged in - Issue
    v.143.0.7499.193
  • Chrome incognito - logged out - works fine
    v.143.0.7499.193
  • Chrome incognito - logged in - Issue
    v.143.0.7499.193
  • Safari - logged in - Issue
    v.18.6
  • Firefox - logged out - works fine
    v.147.0.1
  • Firefox - logged in - Issue
    v.147.0.1
I have also submitted a ticket and waiting for the response. Thanks for reaching out to help Celine
Anu Ojoawo
  • January 19, 2026
I’m experiencing this exact issue.
Nwafor Charles
I’m experiencing this too, especially with the hover effects of my components.
  • January 20, 2026
Lucy_Hill
  • January 20, 2026
Hi ​@Celine_
Thanks to you and the engineering team for looking into this and fixing the bug. It looks to be working fine for me now.
Alexandra Vega
  • January 20, 2026
Hi ​@Celine_
Thank you and the team for the effort into fixing this.
It seems to work be working as usual now.
  • January 21, 2026
Glad to hear it’s working now, thanks for confirming!
M Walther
  • January 23, 2026
Hello ​@Celine_
I am dealing with a similar problem. Problem with instance properties synchronisation (variant, boolean, text) across files
It would be very helpful if you and the figma support could assist me in resolving the issue.
  • January 23, 2026
Hey ​@M Walther , thanks for flagging this! I’ve replied to your DM with some important details on the next steps for the investigation. Please check it when you have a moment.
