Oct 25, 2023 10:50 PM UTC
Components not updating correctly!
Another day, another bug in Figma! 20 billion well spent adobe…Now my component’s which are in linked library’s are not updating correctly. I literally have to go into each component, make a edit by selecting another component state, and then Figma will pop up saying theres an update for this component - i select update ALL as i usually do, but its only updating the selected instance of the component. all other versions of the same component in the same page are not being update until I select them and do the same thing! what is this? what am i paying for? Frustration? a 2gb limit which make creating even a simple flow almost impossible? the limits of this thing are becoming as increasingly problematic as the bugs. Please fix it, also stop double charging for edits, when they are different teams, one person can only make one set of edits at one given time! criminal
Ryan_52
Ryan_52Solution
Technical Quality Specialist
Oct 26, 2023 12:38 AM UTC
Hi @Jamie_Wooster sorry to hear this is happening!
It looks like we need to investigate this further can you please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, share a short video showing the issue you are seeing, include the links to your file and the library file, and share it with support-share@figma.com so they can take a closer look.
Gayani_S
Aug 7, 2024 4:10 PM UTC
Hey @Alexander_Albuquerque, sorry to hear that you’re still having issues!
I’ve reached out to the team internally to double check if there is another way to investigate this, as you’ve mentioned you are not able to share your file link with us. I’ll get back to you once I get more information on this.
Appreciate your patience in the meantime!
Glenn6
Aug 9, 2024 5:55 AM UTC
I don’t see a solution to this and am experiencing the same issue. See linked video for example: https://youtu.be/v5wj5DOSsYE
Master components are kept in a separate Figma file and shared to the appropriate working file. When updates are made to a component and the library is updated the linked assets show up correctly, but the existing component instances throughout the file do not update.
Please help with a solution. Working on large projects and unfortunately cannot build assets that scale.
Sonu_Kumar1
Aug 12, 2024 5:08 AM UTC
I’m experiencing the same issue. I’ve created a design system in a separate file and am using it in another Figma file. However, when I publish a new component in the design system file, it doesn’t reflect in the other file. I don’t know what’s going on. I’ve updated Figma and restarted the app multiple times, but the issue persists.
Gayani_S
Aug 12, 2024 3:36 PM UTC
Hey @Glenn6, thank you so much for sharing a screen recording with us!
I’ve just created a support ticket on your behalf. Your ticket number is #1091855, for reference.
Please share a file link with the team, and invite support-share@figma.com with “can edit” permission so we can look into this further? Note that users with @figma.com emails on your team do not count towards your billing.
Our support team usually takes up to 24 hours to reply back to emails - tends to be quicker than that in normal circumstances. However, please be aware that we are facing increased contact volume so there might be a delay
Gayani_S
Aug 12, 2024 3:41 PM UTC
Hey @Alexander_Albuquerque, are you able to create a test file and share it with us? I can get you also connected with support team so they can Investigate this issue further.
Thank you in advance!
Gayani_S
Aug 12, 2024 3:46 PM UTC
Hey @Sonu_Kumar1, thank you for reaching out! I’ve also created a support ticket on your behalf. Your ticket number is #1091872, for reference.
Please provide a direct link to the file to support, and invite support-share@figma.com with “can edit” permission so we can look into this further? Note that users with @figma.com emails on your team do not count towards your billing.
Someone should be in touch wit you soon. Please be aware that we are facing increased contact volume so there might be a delay.
Appreciate your patience!
Glenn6
Aug 13, 2024 3:18 PM UTC
Thanks @Gayani_S I’ve shared the two files. They are separate files I created specifically to address this issue.
MASTER ASSETS FILE: https://www.figma.com/design/7CBVgGvfqCV16lf01yhuQF/MASTER-ASSETS-FILE?node-id=0-1&t=ptZcSLvYgnGLPvYG-1
MAIN FLOWS: https://www.figma.com/design/nSsFPWe1Az4nahw4OVHPYS/MAIN-FLOWS?node-id=0-1&t=9c0L2rVyRxLGY7Dg-1
Gayani_S
Aug 14, 2024 7:17 AM UTC
Hey @Glenn6, I took a look at your ticket and I did not see that you shared the file links per email, but I can do this for you as an internal note for the team. Also, our support team sent you a reply on Monday, can you please have a look when you have a moment?
Gayani
Glenn6
Aug 20, 2024 4:19 PM UTC
Thank your for your help. Figma support was able to help me understand the step I was missing in my process. I updated the assets file, but did not accept the updates on the working file.
Here is the response that fixed my issues: "It appears that you did not accept the updates available on the subscribed file, indicated by the blue dot on the library icon on the top right corner:
Could you please click on this icon, go to the Updates tab, and accept all updates to the file?"
TE149
Apr 15, 2025 11:41 AM UTC
Still the same Issue. Figma says synced succesful. But the prompt still shows that instances need to be updated. WTF, this is such a beta product and you are asking for a lot of money.
