Caroline Matter
Jul 21, 2026 4:21 PM UTC
Component variant properties break every time — reproducible bug on double-click rename
Hello Figma Support team,
I've identified a reliably reproducible bug in my design system library: every time I double-click a variant in the left panel to edit it a second time, the variant name breaks.
The Prop=Value, Prop=Value name format (e.g. Type=Regular, State=Default) gets overwritten and replaced with just the values, without the property names (e.g. Regular, Default). The right-hand panel then shows "This layer has an invalid name" and the property dropdowns switch to "—".
I tested this on 2 component sets to confirm reproducibility before risking further damage across the rest of the library — the bug happens consistently, so I consider my entire library at risk if I continue editing variants normally.
Steps to reproduce:
  1. Open an existing component set with variants already correctly named (Prop=Value, Prop=Value)
  2. Double-click a variant's name in the layers panel to edit it a second time
  3. The name gets overwritten automatically
What I need:
  1. Confirmation/fix for this bug before I continue editing the rest of my library
Please prioritize this, it is currently disrupting our production team.
Thank you,
Caroline
Celyn_L
Celyn_LSolution
Jul 22, 2026 5:09 AM UTC
Hi everyone, Celyn here. I work closely with ​@Tom Reem.
Our Engineering team has pushed a fix and confirmed that the issue has been resolved. Please refresh your files and let us know if you’re still experiencing any issues.
Thanks again for reporting this and for your patience while we worked on getting it resolved!
Celyn_L
Jul 22, 2026 6:26 AM UTC
Hi ​@mark.braithwaite, thanks for confirming that the original issue appears to be resolved, and I appreciate you calling out this behavior.
I'm checking with the team to confirm whether the variant layer names displaying the full property string is expected and I'll share an update here as soon as I hear back.
Thanks again for flagging it!
Caroline Matter
Jul 22, 2026 1:39 PM UTC
Hi ​@Celyn_L , thank you for fixing this bug so quickly. It's fixed and it's working quite well. However, I'm experiencing the same behavior and feedback as ​@mark.braithwaite. It's true that it works, but it's not very practical.
Celyn_L
Aug 5, 2026 6:14 AM UTC
Hi ​@mark.braithwaite and ​@Caroline Matter, thanks for your patience here.
A fix for this was rolled out a little while ago, and I just wanted to check in to see if you're still experiencing this behavior.
If you haven't already, could you please refresh the tab you're working in and let me know whether you're still seeing the full string displayed on the variant layer name?
Thanks!
Mark Braithwaite
Aug 5, 2026 2:26 PM UTC
​@Celyn_L Thanks for taking action on this. Yes, all seems to be functioning as expected!
Jaycee Lewis
Aug 5, 2026 2:55 PM UTC
Amazing. Thanks for letting us know ​@Mark Braithwaite 🙌 — Jaycee
