Caroline Matter
Component variant properties break every time — reproducible bug on double-click rename
Hello Figma Support team,
I've identified a reliably reproducible bug in my design system library: every time I double-click a variant in the left panel to edit it a second time, the variant name breaks.
The Prop=Value, Prop=Value name format (e.g. Type=Regular, State=Default) gets overwritten and replaced with just the values, without the property names (e.g. Regular, Default). The right-hand panel then shows "This layer has an invalid name" and the property dropdowns switch to "—".
I tested this on 2 component sets to confirm reproducibility before risking further damage across the rest of the library — the bug happens consistently, so I consider my entire library at risk if I continue editing variants normally.
Steps to reproduce:
  1. Open an existing component set with variants already correctly named (Prop=Value, Prop=Value)
  2. Double-click a variant's name in the layers panel to edit it a second time
  3. The name gets overwritten automatically
What I need:
  1. Confirmation/fix for this bug before I continue editing the rest of my library
Please prioritize this, it is currently disrupting our production team.
Thank you,
Caroline
Celyn_L
Celyn_LSolution
Hi everyone, Celyn here. I work closely with ​@Tom Reem.
Our Engineering team has pushed a fix and confirmed that the issue has been resolved. Please refresh your files and let us know if you’re still experiencing any issues.
Thanks again for reporting this and for your patience while we worked on getting it resolved!
Jaycee Lewis
Hi ​@Caroline Matter 👋 Thanks for the detailed write-up and the clear repro steps — that really helps.
I tried to reproduce this on a fresh 2-variant component set and wasn't able to trigger the break. Here's exactly what I did:
  • Created two components and combined them as variants (single Type property, values Regular and Hover)
  • Double-clicked the "Hover" variant's layer name in the left panel — the edit field correctly showed the full Type=Hover string, fully selected
  • Committed with Enter, then double-clicked the same layer a second time to edit again
  • The property mapping held — no "invalid name" error and the Type dropdown stayed intact
  • Quick gif of my test 👇
A few questions:
  • When you double-click a variant the second time, what does the edit field pre-populate with — the full Type=Regular, State=Default string, or already just Regular, Default before you type anything?
  • Are you editing the name in the left layers panel, or somewhere else (right panel, rename dialog)?
  • How are you committing the edit — Enter, Tab, or clicking away?
  • Does this happen on a brand-new file with a freshly created 2-variant set, or only in this specific library?
  • Are you on the desktop app or browser, and which OS? Any non-English keyboard/IME active?
If you can share a short full-screen screen recording of the second double-click, that would likely be very helpful.
Thanks for the additional info! — Jaycee
mark.braithwaite
​@Caroline Matter same issue for me.
Caroline Matter
Hey ​@Jaycee Lewis, thank you so much for your quick reply.
I'm sharing a video of one of my Design System Library components: the Filters button (it's like this on every component). As you can see, initially everything seems normal; the properties are there and correctly assigned. It's when I go into the component's variant a second time to make changes, when I double-click the "Hover" variant's layer name in the left panel—the edit field is incorrect and shows only "Regular" and "Default" before I type anything.
My answers :
When I double-click a variant the second time, the edit field pre-is populated with just Regular, Default before I type anything
I editing the name in the left layers panel
I only worked on Figma the desktop App, on macOS Sequoia 15.6.1 with a standard keyboard
I attached a complete video if my GIF doesn’t work well
Thank you for paying attention to my request — Caroline
Caroline Matter
​@Gabriel Marquis-Angulo I know that you have the same issue in your entire Design System Library
Jaycee Lewis
Hey ​@Caroline Matter 👋 I've filed this with our team to investigate – Ticket ID 2026934. Please keep an eye on your inbox for any requests or replies.
Really appreciate you taking the time to report this so thoroughly!
Jaycee
Tom Reem
Hey ​@Caroline Matter — echoing ​@Jaycee Lewis‘s appreciation for your report. Quick update that our Engineering team is actively working on a fix. Additional updates here: Variant properties (State=Default, Color=Blue) rejected as invalid when renaming layer.
UI_UX_Abbie
​@Jaycee Lewis  Our team have the same issue in Design System Library...😫😫😫
Rong
Hey ​@Tom Reem we’re experiencing the same issue as well. I’ve tried restarting the app, using the web version, and switching browsers, but the issue still persists.
Could you please prioritize this? It is currently disrupting our production workflow.
Thank you.
Celyn_L
Celyn_LSolution
mark.braithwaite
​@Celyn_L first glance seems to be working, though variant layer names now contain the entire string, even if I create a new component. No sure what impact that has other than not being convenient.
