Can't unlink Figma Designs from Jira Issue
Slavko Barac
Hi,
if we click the unlink button the Figma Desgin disappears, but if we refresh the page, the Figma Desgin is still linked to the Issue.
Best answer by Celine_
Hi everyone,
I am working closely with Toku, happy to help!
To give you an update, Atlassian has mentioned that they have released a potential fix for this issue. Could you please refresh and try again?
If you are still having issues, could you please contact Atlassian for further support? We have confirmed that the issue is coming from their side. Thank you! 🙏🏼
  • May 6, 2025
Happens for me as well. I’ve tried clearing the cache for all things Jira and Atlassian too and also changing web browser, but the problem persists. Didn’t use to be like this either, started happening maybe around a month ago or two.
Michael Phillips
I’ve seen the same thing, it looks like the unlink just removes the design visually, but the change doesn’t stick. Probably a bug with the Figma-Jira integration that started recently. You could try unlinking via the Jira dev panel or report it to support so they can look into it.
  • 2544 replies
  • May 7, 2025
Hi all,
Thanks for flagging. We’ve flagged internally with our team. I will get back to you when I have anything I can share with you!
Thanks for your patience.
Toku
  • 4048 replies
  • May 20, 2025
Hi everyone,
Slavko Barac
  • May 20, 2025
It works! Thank you!
  • 4048 replies
  • May 20, 2025
Glad to hear it’s working now, thanks for confirming!
Tenille Zaher
It did not resolve the issue on our side.  We tried in an incognito browser as well and the issue persists.  We’ll reach out to Atlassian.
Hubert2
  • June 16, 2025
Still have the issue here. Any update from Atlassian after the second fix attempt ?
  • June 19, 2025
Works for me now. However, I was in contact with Atlassian support and they did something that fixed it for me. So it didn’t work after only the fix mentioned here in this thread.
Andrea_Ceccarelli1
Works for me but I’ve to do it from figma inspecting the area linked to jira
lep149
  • August 5, 2025
Hi, we’re having this issue too. Is there someone that can help from Atlassian or a tip for resolving?
Emindeka
  • September 17, 2025
I had the same issue and ended up removing the link from the Jira issue by editing the description manually and deleting the embed code directly—kinda clunky, but it worked.
Emindeka
  • September 23, 2025
I ran into the same issue and couldn’t get the designs to unlink directly either. What worked for me was editing the Jira issue itself and removing the Figma embed manually. While organizing my tasks, I started using jira task to keep things cleaner, and it’s helped cut down on mix-ups like this.
