RJO
Sep 17, 2025 3:04 PM UTC
Can't see distances between elements, even in Design mode and after trying everything
Problem description:
Hi Figma team,
Since the last update, I can no longer see the distance between elements when I select one and hold down the Option key (on Mac) while hovering over another. I’ve tried everything suggested:
  • Using Option or Alt + hover over another element.
  • Switching from Draw to Design mode in the bottom right of the interface.
  • Restarting Figma, opening new files, updating the app, clearing the cache, trying the web version, and even disabling plugins.
Nothing has worked and the problem persists, even though I used to see the measurements with no problem before.
I would really appreciate some help, since this tool is essential in my workflow and it’s causing me a lot of issues.
Thank you!
Junko3Solution
Oct 2, 2025 2:04 AM UTC
Hi there,
As some of you may have already noticed, our engineering team has released a fix for the recent issue.
If you’ve run into this problem recently, please refresh your tab and try using the shortcut again to confirm if it’s now working.
Thanks again for flagging this and for your patience while we worked on the fix!
Colin Azeltine
Oct 1, 2025 10:42 PM UTC
Same problem.
Jill_Chan
Oct 1, 2025 10:43 PM UTC
Just happened to me as well.
Ann G
Oct 1, 2025 10:44 PM UTC
Всем привет! Столкнулась с той же проблемой. Надеюсь в ближайшее время это исправят
Syart
Oct 1, 2025 10:45 PM UTC
Im having same issue in MacBook
Figma Desktop App version 125.8.9
macOS Sequoia 15.6.1
Joss
Oct 1, 2025 10:46 PM UTC
Same issue.
Leonid Spektor
Oct 1, 2025 10:53 PM UTC
I’m so glad I’m not alone here. I’ve tried EVERYTHING. My ChatGPT was burning while trying to help me to fix it. 😂
Taylor Roque
Oct 1, 2025 10:57 PM UTC
Hi Figma team,
Thank you!
luis ramirez
Oct 1, 2025 10:58 PM UTC
Same
Joao Janot
Oct 1, 2025 11:00 PM UTC
Seems this problem just happened to a lot of us heh
MBLVD
Oct 1, 2025 11:01 PM UTC
Same issue, thought I was going crazy. Glad it’s not a me problem after all.
Figma Desktop App version 125.8.8
macOS 26.0 (25A354)
