Can't see distances between elements, even in Design mode and after trying everything
  • September 17, 2025
  • 74 replies
  • 4505 views
RJO
Problem description:
Hi Figma team,
Since the last update, I can no longer see the distance between elements when I select one and hold down the Option key (on Mac) while hovering over another. I’ve tried everything suggested:
  • Using Option or Alt + hover over another element.
  • Switching from Draw to Design mode in the bottom right of the interface.
  • Restarting Figma, opening new files, updating the app, clearing the cache, trying the web version, and even disabling plugins.
Nothing has worked and the problem persists, even though I used to see the measurements with no problem before.
I would really appreciate some help, since this tool is essential in my workflow and it’s causing me a lot of issues.
Thank you!
Best answer by Junko3
Hi there,
As some of you may have already noticed, our engineering team has released a fix for the recent issue.
If you’ve run into this problem recently, please refresh your tab and try using the shortcut again to confirm if it’s now working.
Thanks again for flagging this and for your patience while we worked on the fix!
  • September 19, 2025
Hi ​@RJO, thanks for reaching out!
This definitely seems odd. I just tested measuring distances between layers in Figma and ran into no issues using the desktop app or the browser on macOS. I even tested it in Draw > Design > Dev mode with no issues.
Are you using the most up to date version of the app? Is your macOS up to date as well? Is this happening with all types of layers on your canvas or just a specific set of elements?
With a few more details, we can try to pinpoint together what may be causing the issue.
Shamus81
  • September 20, 2025
This seems to be a bug that occasionally happens after updates. Checking if Snap to Pixel or Smart Guides settings are enabled might help restore the distance display.
Rafael Bressan STNE
You should check if there`s any layer behind it, I was just with the same issue and there was a giant component behind my design that was preventing me from getting the correct measurement between frames inside it. I simply arranged the frames correctly and locked the lanes and it is now working again.
borim.kim
  • October 1, 2025
Same happening to me :(
tini_chen
  • October 1, 2025
Same thing happen to me now😔
  • October 1, 2025
Hey ​@borim.kim and ​@tini_chen, thanks for chiming in here!
If the suggestions from Shamus and Rafael didn’t help, can you please answer my initial trouble shooting questions from above?
  1. Are you using the most up to date version of the app?
  2. Is your macOS up to date as well?
  3. Is this happening with all types of layers on your canvas or just a specific set of elements?
With a few more details, we can try to pinpoint together what may be causing the issue together.
Kerby Chiang
  • October 1, 2025
Hey team, this just happened to me as well. Can’t figure out how to resolve it.
  • Yes I’m using the most up-to-date version of the app.
  • This is affecting both the Figma app for MacOS and figma.com
  • I’m on MacOS 15.3 (24D60) but I’m pretty sure this is a Figma issue and not me issue.
  • No, I do not have a giant object obstructing the view. It occurs on every element in a file.
Roman Kolyanov
Hello, I have the same problem ​@djv
1. the newest app
2. macOS Tahoe 26.0.1
3. All types and in different files, even in browser version((
CaseyH
  • October 1, 2025
Same thing happened to me as well. ​@djv
1. Figma Desktop App version 125.8.9
3. All types & all files :(
Adam_Daniel
  • October 1, 2025
Hi! I have the same issue. Super annoying. ​@djv
1. Figma Desktop App version 125.8.8
2. macOS 15.7 (24G222) and web as well
3. Every file
Sean-Skydio
  • October 1, 2025
Just happened to me as well.
annetli
  • October 1, 2025
Janani Ramesh
  • October 1, 2025
Same thing happening here. It was working fine about an hour ago, but now suddenly the Alt key doesn’t measure distances.
LaurelChumbley
Same thing happening to me! Works on my laptop but not my desktop. (Same account logged in both places, same settings, etc)
Jordan Mah
  • October 1, 2025
yup, same thing is happening to me
Daniel Russell
Has just happened to me also.
Figma Desktop App + Browser
Windows 11 / Chrome
All files
Marcinnnnnnnnnnnnnn
Same…….
Shirleyzhao26
  • October 1, 2025
I thought it was just me! I’m on mac and when I press on option, it usually shows me the pixel distance between elements. Now it’s just the duplicate selection tool that shows up! This never happened until an hour ago...
Brent Stainless
same for me, just updated and its gone, mac os, latest os
Hux
  • October 1, 2025
The same issue is effecting me also. Alt/option key doesn’t measure distances on standard app or beta.
  • MacOS 15.7
  • Figma 125.8.9 and Figma Beta 125.9.4
  • Checked in a new, clean file and the same issue.
Colin Azeltine
Same problem.
Jill_Chan
  • October 1, 2025
Ann G
  • October 1, 2025
Всем привет! Столкнулась с той же проблемой. Надеюсь в ближайшее время это исправят
Syart
  • October 1, 2025
Im having same issue in MacBook
macOS Sequoia 15.6.1
Joss
  • October 1, 2025
Same issue.
