Amanda_Espinosa
Sep 21, 2021 10:18 AM UTC
Can't merge my own approved branch
I created a branch as usual, asked for review, got approved, and now instead of the “merge” button it says that I must have editor permission to merge. Which is odd, because I created the branch and everything, I obviously have editor’s permission (I even went to check if I did). I had to ask a collegue to merge it for me.
raquino
raquinoSolution
Sep 22, 2021 9:48 PM UTC
Hi,
This should now be fixed. We identified the root cause and pushed a fix. You may need to refresh your tab in order to get the fix. Please let us know if you are still experiencing this issue after refreshing.
  • R.J.
Denis_Babchuk
Oct 25, 2021 11:05 AM UTC
The same issue. Refreshing tab doesn’t help.
Sukhareva_Ekaterina
Oct 25, 2021 3:41 PM UTC
And I faced such a problem
Julia_Mnizhek
Oct 25, 2021 5:19 PM UTC
Hi! Have the same issue right now.
BTW Thanks so much for the branching functionality ❤️
Julia_Mnizhek
Oct 26, 2021 10:43 AM UTC
Hi! Are there any updates on this issue? Cause I have the same problem.
Thanks in advance 😊
Matthew_Mercer
Oct 27, 2021 7:13 PM UTC
I have a branch in which I’ve made numerous updates. I am now trying to merge the branch back into the main document. It tells me “Conflicts with [file] must be resolved to merge this branch” – but there are no conflicts listed. There are a lot of elements with tags of “Added”, “Edited,” “Removed” – but none of these have any visible or flagged conflicts. Is this purely a bug? And is there a way to bypass this? I could send it to an approver for review but that was my only option.
raquino
Oct 27, 2021 7:24 PM UTC
Hi Matthew,
I’ll DM you for more details.
R.J.
k112
Oct 28, 2021 3:13 PM UTC
Experiencing the same issue. Cant seem to merge my own branch have edit permissions on the file and the org.
Ksenia3
Nov 2, 2021 1:31 PM UTC
Hello, seems I’m experiencing the same issue, I can’t merge, After clicking “merge without approval” (file is mine so no approval needed) the file is not responding for some time and nothing merged after it’s back
wllung
Apr 13, 2023 8:49 PM UTC
hello, same issue. I created this file and don’t seem to have permissions to merge.
Edited: It’s a year later (2024) and I can still count on this issue to dependably happen. Main file lists me as owner and I’m being denied when trying to merge a branch.
Jul 18, 2024 11:17 AM UTC
The issue just happened to me today.
I am the product lead at my company.
I am the owner of the file.
I created the branch.
And i cannot merge without asking a fellow designer to approve my changes.
I also couldn’t address a conflict with the main file (no buttons appeared allowing me to select the main or the branch).
Desktop app on a mac. v124.2.9
