Taher Vohra
May 23, 2025 6:44 AM UTC
Bulk upload images not working on Figma Buzz
So here is what I am trying to do. I have mailer in which there is no change in the content but there is an image with a QR code. Now I have to add 10 different QR codes.
For that I am following below steps:
  1. Generate QR codes as PNG
  2. Add those PNG in an excel file, ensuring each image is paste in a cell (as per the guidelines)
  3. On Figma Buzz, in the bulk create I uploaded the file
  4. After uploading, it shows the column but content is been shown as text (Refer screenshot)
  5. When I select an image the data field remains disabled, but when I select a text layer it gets enabled and when I create assets it just adds text Object
I have tried the same with google sheets but facing the same issue.
y_tokuSolution
May 27, 2025 4:50 AM UTC
Hi ​@Taher Vohra ​@AlexFabuel ​@Tidiane Bazile ,
Thanks for bringing this issue to our attention! Our product team confirmed this was indeed an unexpected behavior and has deployed a fix. The issue should now be resolved.
Could you please reload your tabs and try uploading again? I've tested this on my end and can confirm it's working normally now
If you're still experiencing any problems after reloading, please let me know.
Thanks for your feedback!
Toku
Maciek Szamowski
Jun 11, 2025 12:46 PM UTC
For me still this not works. Tried everything moving files across different hostings, csv to xlsx and now I got [object Object] :(
Aug 11, 2025 3:35 PM UTC
Hi ​@Maciek Szamowski, thanks for following up!
We appreciate your patience. Our Buzz team just pushed a fix for this bug.
Can you please refresh your tabs and let us know, if you continue to run into this issue?
TBoeson
Aug 22, 2025 9:28 PM UTC
Helo. I am still having this issue as well.
Aug 22, 2025 9:59 PM UTC
Hi ​@TBoeson, thanks for letting us know that this still isn’t working for you.
What troubleshooting steps have you tried so far? If your data includes images, can you confirm that you’ve exported as an XLSX file before attempting to upload?
Has this ever worked correctly for you? Are you getting any error messages that you can share? With a few more details, I’ll flag this over to our Buzz team to investigate further.
TBoeson
Aug 23, 2025 2:01 AM UTC
ETA: SOLVED - I didn’t realize that I was needed to actually place the image in the cell. I figured it out. I was placing image path.
Thank you! I am trying this out for the first time today. I am allowed to select the copy no problems, but when I click my image, it will not allow me to select my image column. :( It’s greyed out. See screenshot below. I am using an xlxs and following your tutorial posted.
https://help.figma.com/hc/en-us/articles/31271824185623-Bulk-create-assets-in-Figma-Buzz#h_01JTHA32TKMGQ9YECW9STBFFWF
Agustín_Acevedo
Sep 15, 2025 11:43 AM UTC
Hi! I wanted to report that bulk uploading images through Buzz seems broken.
I had previously managed to upload images via an .xlsx (with images inserted in cells), and it worked fine. But now, even when following the same steps, Buzz only recognizes those columns as text (shows the “T” icon) instead of treating them as images.
Things I already tried, based on suggestions in the other thread:
  • Using .xlsx (not CSV).
  • Making sure images are in cells, not using =IMAGE() formulas.
  • Testing with direct .jpg / .png links.
  • Reducing the file to just 1 image column and <10 rows.
  • Exporting from Google Sheets and also generating .xlsx through scripts.
Nothing worked — Buzz always reads the image column as text. Since I was able to do this before, it feels like a regression.
Is anyone else still running into this? And could the team confirm if this is a known bug or if there’s a workaround?
Thanks!
Sep 15, 2025 10:06 PM UTC
Hey. ​@Agustín_Acevedo, thanks for following up about this issue!
You mentioned that this was previously working for you. When did you start seeing this issue happening again?
And just to confirm, you have added the images in cells then exported as an xlsx file before attempting to upload?
As shown in this thread above, our team was aware of a bug in Microsoft Excel, but they addressed it with an update in May. With a few more details, we can inform that team to investigate.
Agustín_Acevedo
Sep 16, 2025 8:02 AM UTC
Hi, ​@djv Thanks for getting back to me.
Sure, just to clarify:
  • About 48 hours ago, after several failed attempts, I managed to get one file working. Since then, all attempts are still failing.
  • The images are definitely inserted correctly in cells (not formulas).
  • I’m not using Microsoft Excel — I’m exporting directly from Google Sheets to .xlsx and uploading that file into Buzz.
Hope this helps clarify the setup. Please let me know if you need me to share a sample file that reproduces the issue.
AlexSokolenko98
Oct 9, 2025 11:24 AM UTC
Hi! I have a similar problem. I'm trying to upload an XLSX file and it doesn't see the image fields at all. When I insert a CSV file, it does, but only as text. Picture in field L
Oct 9, 2025 8:44 PM UTC
Hey All, thanks for following up and for the additional context!
May I ask if your .xlsx  file is set to Internal mode? Others in the community noticed this was they case because of company policies, but if you switch to Public, it should solve that problem.
