Josh
Former Community Manager
June 22, 2023
VS Code extension — tips if you're having trouble getting set up
Hi there,
The Dev Mode team are looking into the problems some people are having while trying to get started with the VS Code extension, and hope to have updates out soon, but for now have asked us to share the following tips:
  1. The extension is not currently compatible with VS Code Insiders though we’re hoping to have support for this soon. For now we suggest use the regular VS Code version if you’d like to use Figma for VS Code: Download Visual Studio Code - Mac, Linux, Windows
  2. If you are are stuck in a loop of VS Code asking you to “Accept terms and conditions” please log into VS Code before connecting in Figma.
You can log in to the VS Code extension by:
  1. Clicking the Figma icon in the sidebar of VS Code
  2. Clicking “Log In” and following the instructions
  3. You can then click “Open in VS Code” in Figma however, you may need to accept our Terms of Use to allow VSCode to connect.
  4. In order to accept the Terms of Service, you’ll need to click “Next” in the Dev Mode modal.
Once we have any updated information the team will post it here and if you have any follow up questions about these suggestions, or continue to have trouble getting started with the extension we’d appreciate if you can use reach out to the Product Support team directly via this form: https://help.figma.com/hc/en-us/requests/new
Thanks!
    June 22, 2023
    I am having this issue
    So I’m trying to log in in vs code. I go to the Figma icon in the sidebar and in there it has a button that says “Restart login flow”, but when I click it it doesn’t do anything.
    jonenz
    June 22, 2023
    This is my issue also.
    Josh
    JoshAuthor
    June 23, 2023
    Thanks for flagging these ongoing problems with us. We published an update to the extension (version 0.2.1) that should fix these ongoing login issues. Can you try updating the extension to this version and if the problems persist, we’d appreciate if you can reach out to the Product Support team directly via this form: https://help.figma.com/hc/en-us/requests/new .
    Fred9
    June 26, 2023
    Using 0.2.1 i’m stuck on login :
    The figma pane is here
    I click the login button
    Restart login flow show up but nothing append
    June 26, 2023
    I am also stuck at ‘restart login flow’ issue
    June 26, 2023
    Same situation like @Fred9
    I installed 0.2.1 and opened figma panel, clicking figma no result.
    I inspected developer’s tool for VScode, I saw an error below. Hope it helps.
    workbench.desktop.main.js:616   ERR command 'actions.clickLogin' not found: Error: command 'actions.clickLogin' not found
    Windows10, zip archived version of VS code, 1.74.1
    June 27, 2023
    I have the same issue. Immposible to login in figma extention
    Clare_Warburton
    June 27, 2023
    Same issue here, i click the restart login flow and nothing happens.
    June 27, 2023
    Mine works on the oldest version @Figma_Support
    June 30, 2023
    Looking forward to using this plugin! Hope to support the VSCode insiders version as soon as possible, because I’m using Copilot Chat.
