Sep 7, 2023 5:00 PM UTC
It’s baaack: Little Big Updates, but with a weekly twist! 🚀
Little Big Updates are back, but with a NEW weekly twist! 🛠️🎉
What’s coming 👇🏾
→ New updates every Thursday this fall
→ The most updates we’ve ever launched (30+ and counting)
→ Each update designed to make day-to-day life in Figma easier
    Imtiaz_Ahmed_Qazi1
    Sep 15, 2023 8:51 PM UTC
    Thanks for your prompt reply, I tried but, it did not work.
    figma-issue
    djvAuthor
    Sep 15, 2023 10:13 PM UTC
    Thanks for the additional screen recording, @imtiaz_ahmed_qazi!
    Can you please send this over to our support team directly via this form for help? https://help.figma.com/hc/en-us/requests/new
    Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com, so they can take a closer look.
    Imtiaz_Ahmed_Qazi1
    Sep 15, 2023 11:07 PM UTC
    Sure, Thanks, but may be it is because this is my plan:
    Imtiaz_Ahmed_Qazi1
    Sep 15, 2023 11:21 PM UTC
    I did but no result.
    djvAuthor
    Sep 19, 2023 4:56 PM UTC
    A post was split to a new topic: Library updating bug
    djvAuthor
    Sep 21, 2023 5:11 PM UTC
    Little Big Updates Week 3: Fixes to make designing in Figma simpler
    This week, LBU is all about simplifying how you design in Figma:
    10. Select and copy from version history: Users are now able to select and copy items on the canvas while viewing version history. Learn more.
    11. Copy link as Quick Action: Copy the URL of a file via Quick Actions.
    12. Improved link paste treatment: When pasting links over existing selected text, you can now paste and match style so the text you’ve selected will be replaced by the url or email address you want to paste in, rather than auto-link-ifying the selected text. Learn more about this behavior in Figma and FigJam.
    13. Better multiplier export settings: Exporting objects with a multiplier applied sometimes added an extra pixel to width and/or height. This will no longer occur.
    djvAuthor
    Sep 21, 2023 5:14 PM UTC
    Hey @Imtiaz_Ahmed_Qazi1, thank you for your patience!
    Our team will be launching another fix specifically for EDU plans today - be sure to check your component modal sometime later today!
    Please do let us know, if you’re still having issues. 🙏
    Imtiaz_Ahmed_Qazi1
    Sep 21, 2023 6:53 PM UTC
    Sure. Thanks a lot, let me check and I will get back to you.
    Regards
    Imtiaz_Ahmed_Qazi1
    Sep 21, 2023 8:36 PM UTC
    Awesome. Yes, it is working now. Highly appreciated. Thanks a lot. Qazi
    djvAuthor
    Sep 28, 2023 5:57 PM UTC
    Little Big Updates Week 4: Visual improvements to how you work in Figma
    Week 4 of LBU includes small tweaks to the visual experience of designing in Figma:
    14. Offset measurements: When an object is selected, holding option and hovering over another object will show the measurements for offset horizontal and vertical sides of those objects.
    15. Consistent click target for removing effects: Removing an effect could sometimes shift the entire effects list in the right hand panel, moving the click target if you wanted to remove multiple effects in a row. This will no longer occur.
    16. Auto layout: Min/max indicator improvements: While typing within an auto layout object to which a minimum or maximum width has been applied, red indicator lines should now show when the min/max is reached. The red indicator lines will also show when min/max is hit while resizing paddings.
    17. → and ← switch to → and ← in section and frame titles: A bug was preventing “->" and“<-" in section and frame titles from correcting to → and ←. This will no longer occur.
