J.D_Posey
Jun 22, 2023 7:50 PM UTC
Variables + Smart Animate?
Not seeing a way to have variable bool states allow for smart animations in the same way changing variant states allows for it (i.e. if you made a switch that flipped using 2 variants, it’s easy to have them smart animate to each other… but not possible with variables, as variable state changes don’t seem to have controls for animation)
pcote
Mar 6, 2024 11:02 PM UTC
Thanks for explaining! It just make me realize Advanced Prototyping’s UX isn’t very good. Pretty ironic, coming from a company that places design at the core of its values.
Josh_Bernard
Jun 15, 2024 5:31 PM UTC
Where/how are you applying smart animate?
Ziv_Feldman1
Jun 26, 2024 9:22 AM UTC
Work for me
Adams_George1
Jun 26, 2024 2:32 PM UTC
benji.hobson is suggesting below workaround and it worked for me:
Adding any interaction and animation for the component variants.
e.g. In my case, I used Key/Gamepad (leaving the “key” field blank) with Smart animate.
Adams_George1
Jun 26, 2024 2:42 PM UTC
Workaround:
Add any interaction and animation for the component variants.
Metehan_Altuntekin
Jun 26, 2024 3:51 PM UTC
I have been trying this solution for over an hour and couldn’t get it worked. Finally I realized that this only with setting the variable but not with setting a variable mode. I wanna leave this here in case others struggle with the same thing.
dimitrie
Jul 8, 2024 3:32 PM UTC
It’s a bit finicky but works in principle.
I have yet to see a good demo file so I made one myself. The demo changes a square into a circle. It includes two examples. Basic instructions:
  • Create a string variable with its value set to the default variant name of the target component.
  • Assign that variable to the component inside your prototype frame (nothing changes)
  • Set up a click prototype interaction that changes that variable value to the new variant name on a controlling component (like a button).
  • Make sure that the target component (that will be changed) has animations changes set up with “on click” or “keypad” (can be empty) that smart animates them into the other variant.
Figma – 8 Jul 24
Smart Animate Example with Variables setting the Component Variant.fig (61.9 KB)
