Stanislav_Carla
Mar 14, 2024 11:42 AM UTC
Variables from an external library added to the file are not showing up when trying to assign them to a value of a local variable
Some of my colleagues have the same issue. They are editors in a file. The libraries are enabled, everything seems to be set properly. Did you manage to find a solution?
djvSolution
Mar 18, 2024 5:55 PM UTC
Hey All, sorry to hear you were having trouble with your libraries and apologies for the delayed reply!
This sounds related to a bug that we had and launched a fixed for a few days ago. This should have fixed itself if you were able to relaunch or refresh your tabs.
Please let us know if you’re still having issues.
Feb 27, 2025 7:48 AM UTC
HI ​@Aleem ​@Frank_De_Graeve1 ,
Sorry for the delayed response! Do you know if the missing variables are specific to a certain type (like text, color, or numbers), or are all variables missing entirely?
Could you please check that the library files are in a project rather than still in Drafts?
I'm trying to replicate the issue, so any additional details you provide would be greatly appreciated!
Toku
Aleem
Feb 27, 2025 10:11 AM UTC
OK. I’ll do as guided now and update you in a jiffy.
Aleem
Feb 27, 2025 10:14 AM UTC
The library file is confirmed to be inside a Team project folder and not in a Drafts.
Next Generation
Jun 12, 2025 6:50 AM UTC
having same issue Some applied library variable disappeared suddenly while working my new file but in same project where main file is. I have checked in main file library has all the variables in it. its properly published. As I was able to access all variables in new file before and they just disappeared some hours ago i am sure there is some kind of new bug introduced
Next Generation
Jun 12, 2025 11:37 AM UTC
Problem solved variables were hidden form publishing form settings
