Stanislav_Carla
Mar 14, 2024 11:42 AM UTC
Variables from an external library added to the file are not showing up when trying to assign them to a value of a local variable
Some of my colleagues have the same issue. They are editors in a file. The libraries are enabled, everything seems to be set properly. Did you manage to find a solution?
djvSolution
Mar 18, 2024 5:55 PM UTC
Hey All, sorry to hear you were having trouble with your libraries and apologies for the delayed reply!
This sounds related to a bug that we had and launched a fixed for a few days ago. This should have fixed itself if you were able to relaunch or refresh your tabs.
Please let us know if you’re still having issues.
Mar 21, 2024 8:47 PM UTC
Glad to hear that, @Jeremy_Knudsen!
Please let us know if you run into any further issues.
Apr 29, 2024 3:43 PM UTC
I’ve the same issue, suddenly variables from the connected library are not showing in design files. Tried to clear the cache, relaunch, even link it to a new test file. Any idea?
Apr 30, 2024 3:16 PM UTC
Hey @Moataz_Galal_Eldin, sorry to hear this is happening. This is likely a new issue, since a fix for this topic has already been pushed.
Please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com so they can take a closer look.
May 29, 2024 7:46 AM UTC
I have the same issue
May 29, 2024 8:55 PM UTC
Hey @hana.klust, we pushed a fix for the original issue on March 18th.
Since this is likely a new issue, please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to the file, and share edit access with support-share@figma.com, so the team can take a closer look.
mbeyer
May 30, 2024 8:59 AM UTC
Don’t know, if it is the exact same issue, but I ran into a similar issue yesterday:
I have a library with all my text variables, size-xs to size-xxl, line-height-xs to -xxl etc. you get the idea.
I was working on a file, where I had included this library (amongst others), when suddenly all the sizes disappeared when I tried to apply them to a new(!) text element.
The elements I had applied them before still had their variables, but they didn’t show up for new elements. Funny enough, not all text variables vanished, only weight and size. line-height, kerning etc. all were fine.
I managed to get them to work again. Seems like the filtering (only show this var in text context etc.) doesn’t work cross files anymore. Once I manually set them all to appear in all input fields and republished/updated, it worked again.
Ekaterina20
Sep 10, 2024 9:06 AM UTC
I had the same issue today, when it would be fixed?
Sara_Jonason
Sep 13, 2024 5:53 PM UTC
Me and the developers I’m working with have the same issue it seems. I’ve assigned a style to elements, but they as viewers can only see the HEX code. They have access to the color library and can see color styles of the same library for previous elements but not for new.
Any fix for this?
Frank_De_Graeve1
Feb 6, 2025 8:15 AM UTC
Any news on this?
Aleem
Feb 25, 2025 10:57 AM UTC
