BradleyA
May 21, 2025 10:05 AM UTC
Updates in Design System not updating in other files
I am pushing updates from my design system and when updating the instances in external files I am not seeing changes. For context, I had some cards with an outline in my design system, I have now removed these outlines and updated various times in the other file and still I am not seeing the outlines disappear.
I have even tried the ‘repair component connections’ command I have seen in other posts and that has not worked, even though it said it repaired various connections. After pushing another update after this was done the outlines are still on the cards. What is the point in the design system if I can’t make changes at the source? Now I have to remove the outlines from each individual card in my other file, this is very frustrating.
Dylan_Ondell
May 21, 2025 2:53 PM UTC
I believe I am having the same issues. I just recently went through and updated my teams Design system to apply variable values to all of the components. When I go to use the component in another file it is still showing all of it’s original values - no variables applied. It’s even kept properties that I completed removed in the Design system.
One thing I tried with another component was deleting the entire component (variant group and all) and completely rebuilding it. This seemed to have fixed the issue, but I would like to not do this to every component.
Dylan_Ondell
May 21, 2025 3:02 PM UTC
I may have found a solve. Seems like a weird bug potentially occurring, but unlinking and relinking the design system to the specific file resolved my issues.
Update: Scratch that didn’t work. Some components are totally fine, but then some variations of some aren’t updating properly.
Glennis1
Jun 5, 2025 1:00 PM UTC
I’m having the same problem.  Sometimes an update of a component flows through to the design file, and sometimes it doesn’t.  This seems to be an issue for me just recently.
Tricia Spoonts
Jun 5, 2025 2:11 PM UTC
I am also having the same problem.  I created some new colors in the library, but when I try to use them they show up with completely different colors.  These are not colors I have ever added to the library.
Jun 9, 2025 11:44 AM UTC
Hi everyone, sorry to hear you're running into issues with your Design System updates not reflecting in other files!
To cover some basics, here are a few temporary solutions that may help:
  •  As ​@BradleyA mentioned, try using the “Repair component connections” in the quick action to see if that resolves the issue.
  • You can also try the “Regenerate all instances” command (found in the same menu) and check if the instances then update correctly.
  • If that doesn't help, another workaround is to apply a small change to the main component to trigger an update.
    Here’s how:
    - Go to main component, make a minor edit in the component (that you can easily remember and undo afterwards) —like adding a stroke or slightly adjusting font weight.
    - Publish the update.
    - In a different file, accept library updates and insert an instance of that component. Check if the issue is resolved.
    - Return to the main component and undo the test change you made.
    This approach usually helps “reset” the instances / assets and bring them back into sync.
If you’ve gone through these steps and still aren’t seeing the updates in your files, our support team can take a closer look by submitting a bug report.
In the form, please include:
  • A link to the affected file with can edit access granted to support-share@figma.com
  • A link to the file where your library is located. Please note, granting access to this support account will not affect your seat count or incur any additional charges.
  • A brief description or a short video showing the issue
    Thanks!
piotrek
Jul 2, 2025 3:29 PM UTC
Tried all solutions from this thread and still not working for color variables. My Case:
FIle A - updating color Variable 1
File A - publish changes
FIle B - no library update visible
File B - component X with Variable 1 still have color hex not updated, but it has the same variable name. after manual  giving Variable 1 color is changing
Tried the same thing with string Variable (for fonts style) - after updating File B, changes are made automatically for component X
UD ved Christian
Nov 17, 2025 1:50 PM UTC
Same issue. Only way to update a component is to delete the instance and re-insert the same component from the library. Reset or any amount of time does not solves the issue. I have the same issues with all types of assets. Colors, tokens, new items. for all my instances. The issue is not within the same file, just linked files.
A solution would be much appreciated :)
Nov 18, 2025 11:36 AM UTC
Hey everyone, thanks for flagging this, and sorry the workarounds haven’t helped in your case.
Since this is affecting multiple asset types across linked files, the best next step is for our support team to take a closer look. When you have a moment, please reach out to them with a link to a copy of your file (and grant edit access with support-share@figma.com) and the steps you’ve already tried. That will help the team investigate what’s going on more effectively with you specific case.
You can submit a ticket here: Submit a bug report. Thanks again for your patience!
UD ved Christian
Nov 19, 2025 12:15 PM UTC
​@Celine_  I’ve spent the last 15 minutes trying to submit a bug report. After dealing with countless pop-ups and searching through multiple AI bot suggestions and topic-based solutions, I’ve given up. I understand the need to streamline or filter requests, but this level of complexity is unlike anything I’ve seen before.
Is there a direct email address or a simple way to send in my request? Getting support shouldn’t be this difficult.
Nov 19, 2025 1:16 PM UTC
Sorry for the disruption here, we’re actively reviewing the support form experience, and your feedback is really valuable. I’ve shared it internally with the team.
I’ve also created a support ticket on your behalf. Your ticket number is #1606798.
Please check your inbox when you have a moment (I sent it to your address mail: bixxxxxy@mxxxo ). Feel free to add any additional details directly in your case so the team can take a closer look. Thank you!
