Jun 28, 2023 11:01 AM UTC
Unable to switch variable modes
I set 4 color themes (variable modes) for my design in local variables but when I’m trying to switch them, 3 color themes are greyed out in the dropdown. Is it a bug or I’ve done something wrong?
Josh
JoshSolution
Former Community Manager
Jul 25, 2023 9:37 PM UTC
Hey all this could be due to the variables in your selection being on different versions with one version having access to fewer modes than the other one. If you update everything (variable collections, and make sure components using variables are published with the latest variable version), then all modes should become available for use.
Hope this helps. 🙂
Rob_Winters
Oct 11, 2023 2:43 PM UTC
Hi. Also having this issue as well as other issues with variables. Seems very buggy right now. I’ve even deleted all frames so nothing is being references and I’m still seeing the faded out modes, and also variables that have previously been deleted. Libraries appear to be up do date. Seems to start OK with a clean file but some breaks down when I start bringing in component. Even simple ones where I know only correct variables are being used.
Oct 13, 2023 2:44 PM UTC
Hi All, i am facing a same problem here, can’t access the variable which is inside a different mode, not able to toggle the boolean value between modes.
Oct 20, 2023 3:30 PM UTC
Hello, I’m also facing the same problem. In the library file that I’m working on I added a fourth mode and it is disabled. I can’t even use it in the file where I created it…
Nov 6, 2023 8:28 PM UTC
same issue, updated all the files but the instance won’t give me the other color variables (greyed out). Even after updating everything, even if I detach an instance, I haven’t tried detaching all the components but then I would lose all my updates if I detach.
Isabell_Herzog
Nov 16, 2023 6:10 PM UTC
Dear Figma Support,
I’m catching the same problems as many others do/did: I’m sometimes and quite randomly unable to switch between my color themes.
BUT in my case it makes completely no sense. Because it has nothing to do with my colors! My colors are connected to my “design system color variables”. In the following video, I’m showing you two nearly identical master screens.
Within the left one, it is possible to switch themes.
Within the right one, it is not possible to switch.
It took me 8h to find a reason. And you know what? – I didn’t find one 😪
Please let me know if you guys know more. 🔎 Because I don’t get it! For me, it is essential to be able to switch between color themes.
Thanks 👋
Isabell_Herzog
Nov 16, 2023 6:33 PM UTC
bug reported
Antonio_Lapa
Dec 4, 2023 10:53 AM UTC
Hey everyone, this is super helpful and it’s good to know that I’m alone in this. Is there already a way to troubleshoot this to anyone’s knowledge? I’m still encountering the same issue as all of you 😬
Jan 4, 2024 12:22 PM UTC
Hi Josh, any answer regarding to this bug? It has been more than 6 months since we published it.
If I am paying an enterprise license to have more variable modes I would like an answer…
