Toph.FR
Jun 26, 2023 1:34 PM UTC
Transparency in variables workaround? (Material 2 troubles)
In Material Design 2 (M2), there are a lot of elements made out of a color from the palette (hex code, no opacity) and an transparency depending of the expected result.
For example, a primary text can be a solid #000000 and a secondary text the same #000000 with a transparency set to 64%, resulting in a grey text blended with the background color.
My design system uses the same approach today.
Therefore design tokens works like this:
  • Color Palette tokens are based on a hex code
  • Color Usage tokens are based on Color Palette tokens + opacity %
While playing with the new Variables feature in Figma, I noticed that it seems not possible to set an opacity to an existing variable. We can set an RGBA value, but no Variable + Opacity as far as I know.
Plus, looking at Unlock design system scalability with variables presentation during Config 2023, it seems that variables for Opacity will come in V2, but looks like there’s no plan to apply opacity on a color variable in a “parent” variable…
M3 is using plain tones now, but since lots of Designers & Developers are still using M2 guidelines I wonder if you guys have already found a way to deal with it without creating hundreds of variants for each colors with different opacities — which is completely opposed from variables logic in my opinion ?
Philip_Lundgren
Oct 2, 2023 2:25 PM UTC
Second this. Figma, PLEASE let us use variables but set a different opacity somehow. I don’t want 12 opacities of one color in my variable set…
Anthony_Swierkosz
Jul 10, 2023 6:25 AM UTC
This has been an issue even before variables, but now that variables are being added I really hope it will be solved. I think it’s because color and opacity seemed to be linked in most instances (like fill styles / color variable includes opacity).
  • Having the option to separate color and opacity into two separate variables would solve this. (Color variable with just hex/rgb/…, opacity/number variable able to be used as opacity )
  • Alternatively, similar to the current alias implementation, having the ability to use an existing color variable (just linking hex/rbg/etc. without opacity) in another color variable would solve this. Such as a BLACK variable (#000000 - 100%), being used in another color variable (BLACK - 40%), “BLACK” being an alias.
Philip_Lundgren
Mike_Nino
Feb 8, 2024 10:32 PM UTC
Any word on when this is going to be available?
Feb 12, 2024 2:20 AM UTC
Hey all,
Thanks for the feedback. Just to confirm, is your request same as this: (Variables: Color alias with alpha / opacity (rgba ideally)?
If that’s the case, you can upvote! Our product team will take it into consideration for future enhancements!
If I’m misunderstanding, please let me know.
Toku
KennLucas
Mar 25, 2024 8:38 PM UTC
If that’s the case, you can upvote! And our product team will ignore the needs of actual users as always!
Calvino_Miguel
Nov 30, 2024 12:01 AM UTC
What’s the current state? I am exactly facing this issue too.
yarhugaab8
Dec 1, 2024 1:45 AM UTC
Thanks for sharing. It help me a lot.
MarkT
Apr 14, 2025 12:31 PM UTC
​@y_toku is there any progress on this issue. This was marked as “solved” ! It does not look like it was solved. Thank You.
