Aleksander_Klajderic
Feb 11, 2021 12:16 PM UTC
Toggle Show/Hide UI not working on Windows since Ctrl + can not be pressed
At least on European keyboards (don’t know about the others) there is no dedicated backslash button. Therefore I can not use Ctrl + \ to show or hide the UI of the Figma web app.
Keyboard combinations with Alt are not working.
If I hide the UI with the help of the menu, I can not Show it again since the menu is part of the UI. !!??!
Federico_Dion
Jan 26, 2024 11:59 AM UTC
wowwwwwwwww thank you sooooo much!
HosokawaR
Feb 5, 2024 9:06 AM UTC
In my case it was conflicting with 1Password ctrl + \ shortcut.
Environment: Windows 11, Figma desktop app, US layout keyboard
Theo16
Feb 6, 2024 11:33 AM UTC
I had some issue with my french azerty keyboard with the “@” key to hide/show UI.
Just figure it out that you have to press “²” and it works perfectly
De rien 🙂
Caimi_Piccinni
Mar 11, 2024 5:56 PM UTC
It worked for me to change the keyboard layout to “generic”. To do that: first go to the “?” symbol to the bottom right of the screen; in the menu select “change keyboard layout”; in the keyboard panel that appears select “generic” from the small menu on the left. Done.
Benny_Stuhler
Mar 15, 2024 8:41 AM UTC
For the german folks who have this problem:
In Figma it says that you should press ^ but you actually need to press this “<” key
Felipe_Martins1
Apr 3, 2024 6:49 PM UTC
I had the same problem and what worded for me was Ctrl + ]
Holse_Mattias
Apr 10, 2024 11:52 AM UTC
They “solved” the problem for some languages some 20 days ago.
Normally you need to press §. But for some reason it does not work anymore.
Maybe we just need to be even more patient… who knows.
Apr 19, 2024 7:38 PM UTC
Command + . for me (Mexico)
Apr 28, 2024 12:15 AM UTC
OMFG! 2 years I’ve struggled to find why this does not work. Indeed, 1Password was conflicting with this.
THANK YOU! 🙏
I wish there was a way to see all the app level shortcuts in windows in one place.
Emirhan_Dikci
May 2, 2024 7:06 AM UTC
CTRL + Ç (for Turkish)
