Aleksander_Klajderic
Feb 11, 2021 12:16 PM UTC
Toggle Show/Hide UI not working on Windows since Ctrl + can not be pressed
At least on European keyboards (don’t know about the others) there is no dedicated backslash button. Therefore I can not use Ctrl + \ to show or hide the UI of the Figma web app.
Keyboard combinations with Alt are not working.
If I hide the UI with the help of the menu, I can not Show it again since the menu is part of the UI. !!??!
StLa1
Aug 3, 2022 7:33 AM UTC
Oh I thought you could pass it to the team, no problem
Tiago_Pereira_Pessoal
Aug 24, 2022 5:37 PM UTC
Valeu Pedrão!
lyk_impact
Sep 2, 2022 6:03 AM UTC
For nordic (at least danish) it is ctrl + ½
Hector_Martinez
Nov 13, 2022 9:47 PM UTC
With a Latin American keyboard, I type Ctrl + | (the symbol left, next to the 1) for toggle figma UI
Olivier_Dalban
Dec 15, 2022 1:27 PM UTC
ça ne marche pas pour moi les gars, pourtant j’ai un clavier 100% français…
C’est bien cmd + accent grave ? la touche où il y a le signe £ ?
Gyongy_Daniel
Mar 25, 2023 12:01 PM UTC
Fgima show/hide on a Hungarian keyboard is CTRL + Ű
May 23, 2023 10:42 AM UTC
It seems the shortcut has changed, it’s @ now.
If you want to see the key mapping according to your keyboard type, go to the “layout” panel of keyboard shortcuts: [Select keyboard layout – Figma Help Center] https://help.figma.com/hc/en-us/articles/5665442977431-Select-keyboard-layout
For me, show/hide UI shortcut is key “²” at left of the 1 (french Azerty on Windows)
Nov 6, 2023 12:50 PM UTC
I love you for this hint! Thx! <3
Dec 2, 2023 9:26 AM UTC
thank you so much. I was struggling to find this out. 😃
Bez1
Dec 27, 2023 8:35 AM UTC
I have a similar issue on a US keyboard on windows.
There are three “/” keys on the keyboard,
on The “Q”, above the Numpad, and next to right Shift key.
The problem is the Ctrl+/ (on the “Q”) quits Figma
the other two “/” are opening a search box, so If I hide the UI through the menu,
I can’t get it back unless I quit Figma and open again.
It used to be another key, I think in the past it was Ctrl+. or Ctrl+, and it worked
but now I don’t have a shortcut anymore to hide show UI and it’s really hindering my work…
