Holyoaa
Apr 16, 2024 9:39 AM UTC
The preview is blurry, when you zoom in everything is fine. What's the problem?
Everything is fine in the browser version. Idk what happens
LiceliaSolution
Jun 5, 2024 6:55 PM UTC
Hi, I experienced this same issue -
For me at least changing the Preview Settings solved it:
In the top right corner under Zoom dropdown > Pixel Preview > Disable
Image shows pixelation if “1X” is selected, and it goes away once Disabled.
Hope this helps anyone.
jo1
Jun 20, 2024 6:24 AM UTC
Hi dvaliao
Is there an email i can use to raise a ticket please?
I cannot share the file.
thanks
Jun 20, 2024 3:25 PM UTC
Hey @jo1, you can use the link I provided to submit a ticket in my previous response:
https://help.figma.com/hc/en-us/requests/new
Jul 8, 2024 9:22 PM UTC
I found a fix for this. In my case, my artboards are all 2560x1440
If I set the Prototype Device to “Custom Size” and set the width and height to be 1 pixel less than my art boards, it renders clean. If I set it to None or to the exact pixel size, it’s blurry when the browser window is a greater resolution than the artboards.
I work on a 6K monitor but design for screens that are smaller than mine, so the issue is visible for me 100% of the time. I have a feeling folks reporting the same issue are also working on screens larger than they’re designing for – a super common use case for product design!
This seems like a clear frontend bug.
Jul 11, 2024 7:53 PM UTC
I’m a new user, so I can’t post more than 1 media attachment per post. So following up with how text looks on my 6K monitor w/ 2560x1440p artboards without my workaround (the “before” screenshot if you will)
And here’s how it looks with my workaround:
As you can see, it goes from blurry to crisp if you make the Prototype resolution 1px (sometimes as much as 8-10px) narrower / shorter than the Frames you’re presenting.
Aug 15, 2024 10:50 PM UTC
Same issue - Pixel preview disabled - it will come into focus for a second and immediate goes back out - previously it might be pixelated for a second of 2 but would get clear right away - any other fixes for this?
