Wei_Qing_Yu
Mar 9, 2021 10:07 AM UTC
Textlink (underline) didn't work
Hei, I discover interaction between normal text and text with underline not work. One component is normal text the other is with underline. At first the hover effect worked without text input changing. When I changed text in the instance, then interactive effect disappeared.
nikolasklein
Mar 9, 2021 2:01 PM UTC
Hey there,
can you try reloading your prototype and maybe share a file. It works on my end!
— Niko
UX_Designer
Jul 7, 2022 12:57 PM UTC
Hi,
I’m experiencing the same issue…
When using a ‘hover’ interaction, the variant of the component is showing but not the underlining of the text. Is there a solution for this?
Thanks
Nick40
Jul 15, 2022 3:28 PM UTC
This is still an issue - 1 year later.
Can this bug be prioritised please?
Stanley_Haladej
Aug 7, 2022 3:41 PM UTC
Hello? Still an issue. Having trouble in my usability testing, because underline on font does not show in prototype for some reason.
Nic_C
Aug 8, 2022 3:26 PM UTC
Same problem here! Please fix this Figma team 🙏
Jul 5, 2024 2:36 PM UTC
I’m still having issues with this?
Weronika2
Jul 11, 2024 2:59 PM UTC
I am still having this exact issue, someone help D:
Lachlan1
Jul 18, 2024 2:10 AM UTC
We’re facing this same issue on link-style CTA components. What’s weird is that it’s only an issue when the hover variant removes the underline. It works fine if the hover effect adds an underline.
Essentially we have a component where:
  1. The Default state has an underlined text-label
  2. On-hover, we switch to a variant without the underline and change the text colour
  • When we create an instance of this component, and don’t override anything the interaction works as expected
  • BUT if we override the label e.g. from “Label” to “Read more” the underline is not removed on hover. What’s weird is the colour still changes but the underline inconceivably sticks around
What’s even weirder is that if we swap the states (no underline by default, and underline on hover) everything works perfectly as expected.
Wild that this is still a bug more than 3 years later!
dudenas
Feb 12, 2025 11:21 AM UTC
Still not fixed
