Wei_Qing_Yu
Mar 9, 2021 10:07 AM UTC
Textlink (underline) didn't work
Hei, I discover interaction between normal text and text with underline not work. One component is normal text the other is with underline. At first the hover effect worked without text input changing. When I changed text in the instance, then interactive effect disappeared.
Bastien Moiroux
Feb 19, 2025 9:43 AM UTC
Very annoying to have this issue since 3 years
iago
Feb 20, 2025 9:34 PM UTC
Make sure when you hover over the text layer (on design mode) is shows the link on a tooltip, if you select the layer you also should see this icon in blue, this is what matter, not the visual with the underline
Nonetheless, you can try this:
  • Select the object (text layer)
  • select the prototype tab
  • add interaction trigger to on click and action to open link
Lotte Camilla
Mar 13, 2025 8:12 AM UTC
Still same issue :(
MrodeBOCO
Mar 19, 2025 8:53 PM UTC
Also struggling with this! Please fix
MrodeBOCO
Mar 21, 2025 5:20 PM UTC
I’m back--for those struggling with this, I found that my issue was fixed by breaking the assigned text style I had in the component.
My component had a default state (a text style defined by me), then when I hovered, I wanted that text style to modify and become underlined.
I think the system had a problem overriding the text style to underline? I broke the link and now it all works well. Still a pain that I have to disconnect styles for this to work...
Jen P
Jul 18, 2025 5:56 PM UTC
Thanks for this!
Yes - breaking the style on the hover state did work for me too.
In addition I then went in and created a new text style that also had an underline.
I then linked it on the hover state - it works perfectly.
