philphil
Apr 5, 2025 8:33 AM UTC
Rounded Rectangles Like Arrows in FigJam
Hi everyone! 👋
In FigJam, I love how you can create arrows and then reshape them freely by adding angles, and the corners stay nicely rounded no matter how you move the handles.
I’m wondering:
👉 Is it possible to do the same in a Figma Design file, but with a rounded rectangle instead of an arrow?
Basically, I want to create a shape starting with a rounded rectangle and I want to be able to add angles to it (just like how arrows behave in FigJam), while still keeping the rounded corners.
Does anyone know if that’s possible? Or maybe a workaround / plugin that can help?
Basically I want to be able to reshape the rounded rectangle easily without the corne radius to change and be able to add angles like I want. How can I create easily a rectangle like the purple one in my pic?
Thanks a lot!
Nellya
Power Member
Apr 5, 2025 8:51 AM UTC
Hi. You can use Union for that. Here is example
philphil
philphilAuthor
Apr 5, 2025 9:08 AM UTC
Oh my god the second square you put with the rounded is what I wanted I think, I want the same shape to be able to have the same rounded corner. Can I then change the corner radius as I want?
How do I activate Union ?
philphil
philphilAuthor
Apr 5, 2025 9:11 AM UTC
I am trying to have rounded corners here, like you did as well
Nellya
Power Member
Apr 5, 2025 9:15 AM UTC
Yes, you can do it anytime
Make sure you put them in Union. I showed it in the video — just select your rectangles and choose Union Selection in the right panel.
philphil
philphilAuthor
Apr 5, 2025 9:18 AM UTC
Yes I looked at your video, but I don’t find it in the right panel. How can I see it?
philphil
philphilAuthor
Nellya
Power Member
Apr 5, 2025 9:26 AM UTC
Oh, you use the old interface. In that case, it's here
philphil
philphilAuthor
Apr 5, 2025 9:33 AM UTC
I don’t manage to have the rounded corners ‘outisde’ like you did…. I want to do that
Don’t want a 90° angle.
On the left, it’s considered a Union now. Could you help please? I’d be supeeer helpful
Nellya
Power Member
Apr 5, 2025 9:35 AM UTC
Select Union layer group and change the corner radius from 0 to any you want
philphil
philphilAuthor
Apr 5, 2025 9:42 AM UTC
Yes now I selected the group and I can I guess ! Amazing. Thank you so much for your help Nellya, it was supeeeer helpful :)
Just how to get to the new interface? Cause I was lost back then when they introduced the new one, so I kept the old one.
