Alex_Arutuynov
Aug 19, 2024 5:28 PM UTC
Resizing issue with autolaout
When I’m trying to manually resize the container frame (using cmd+alt), which contains 4 different frames with an elements inside of it. These elements start moving chaotically, leaving the parent frame and ignoring the constraints of it, for some reason the main frame size is effecting the position of these elements, but they shouldn’t move.
Before:
After:
What is happening here? Did Figma change the shortcut or behavior again?
test file
Figma – 19 Aug 24
Alex_Arutuynov
Aug 19, 2024 5:59 PM UTC
I should also mention a problem with the constraints UI buttons, I simply can’t just click to the center of it, doesn’t work. Idk why it’s not working (Desktop app MacOS Ventura 13.4),
it’s getting extremely frustrating…
Sep 12, 2024 1:21 PM UTC
Hey there! Thanks for flagging this, It seems that you encounter a similar issue flagged by another user here:
Our team has worked on a fix, please refresh your tab to see if that helps. Thank you!
JuliesZ7
Sep 16, 2024 2:58 AM UTC
I’m glad to hear that! I’ve tested it out, and it’s working perfectly now. Thanks for listening to our feedback! 🥰 😍
