Malak Elkafoury
Apr 20, 2026 12:55 PM UTC
Re-registration of deleted account
Hi, I deleted my account because I accidentally saved my last name incorrectly and I couldn't change it to be written exactly as my student id to be verified for the educational plan, However I'm currently trying to create a new account using the same email, and it sends me a message "your request has failed".... Why is this happening? and when will be the suitable time for signing up again as I am in the run-up to a deadline, and I’ve already tried
  • Opening an incognito/private browsing window
  • Trying a different browser
  • Switching the wifi to mobile data
  • Disable any VPNs or browser extensions        as mentioned before, I hope someone from Figma can come across this as fast as possible please, thank you
Celyn_L
Apr 21, 2026 8:32 AM UTC
Hi ​@Malak Elkafoury, Celyn from Figma Community Support here.
Thanks for sharing all the steps you’ve already tried, that’s really helpful.
I understand that you deleted your account to correct your name for Education verification, and now you’re running into a “your request has failed” error when trying to sign up again with the same email.
This can happen when an account has been very recently deleted, as it may take some time for that change to fully process on our end.
If you haven’t already, could you try signing up again now from a web browser and let me know if anything has changed?
Given your upcoming deadline, I’ve also gone ahead and created a support ticket for you so the team can take a closer look and help unblock this as soon as possible — your case number is #1861162.
Someone will be reaching out via email shortly, so please keep an eye on your inbox. We’ll do our best to help you get back on track quickly.
Joey Pham
Jun 2, 2026 1:26 PM UTC
Hi, I am having this issue too.
I created an account and then deleted it because was going to sign up through an organization. Now when I try to create a new account, it hits me with the “Your request has failed”.
Jun 2, 2026 2:15 PM UTC
Hey ​@Joey Pham , Celine from Figma here, stepping in for Celyn!
I’ve replied to you directly via your Forum post, please check directly there:
rocio_eme
Jun 2, 2026 7:58 PM UTC
Hi! I’m having the same problem! Could you please help me?
I sent a request and received an email with the # (help.figma.com/hc/requests/1940194).
I will be pending of the response.
Thank you in advance!
Best, Rocío.
Jun 3, 2026 9:27 AM UTC
Hey ​@rocio_eme , thanks for reaching out to us! I took a look on your case, and the support agent has replied to you. Please check your inbox when you can, thanks!
rocio_eme
Jun 3, 2026 2:38 PM UTC
Hi Celine! How are you? I sent my response about an hour ago! Sorry for the delay! Thank you in advance! I tried to create the account today but it still doesn’t work. Thank you!
Jun 4, 2026 9:00 AM UTC
Hey ​@rocio_eme , I am good, and you? I can see in the backend that the support agent confirmed that your Figma account was successfully created today. 🙌🏼
If you are still having issues, feel free to reply directly to your support ticket for further investigation, thank you!
AlizS
Jun 16, 2026 6:58 AM UTC
Hey! I’m experiencing the same issue. I cannot re-register with the same e-mail address (deleted recently.) Even from an incognito window (Chrome), or a different browser (Safari) it doesn’t help and says the same error message “Your request has failed”. Could you look into this? Thank you!
Celyn_L
Jun 16, 2026 7:13 AM UTC
Hi ​@AlizS, I'm sorry to hear you're running into the same issue. I understand you're trying to create a new account using an email address that was recently associated with a deleted account, but you're still seeing the "Your request has failed" message even after trying different browsers and an incognito window.
In some cases, when an account has been recently deleted, it can take a little time for that change to fully process on our end. Could you try again after 24 hours? That usually gives enough time for everything to clear, and you should then be able to reuse the same email address.
Should the issue continue after 24 hours, please submit a bug report through the Support Hub by following these steps:
Support Hub → Start a chat → Type "Report a bug, cannot create account" → Press Enter and follow the prompts.
When you submit the report, please also include the email address you're trying to use so the team can take a closer look.
Thank you for your patience, and I hope you're able to get back up and running soon!
AlizS
Jun 16, 2026 2:45 PM UTC
hey ​@Celyn_L thank you for your reply. I would need to create the account very urgently, unfortunately I cannot wait 24 hours. I have opened a ticket in the troubleshoot method you mentioned. Can you look into this further? Thank you.
