Millaray_Campos_Zuniga
May 20, 2022 2:25 AM UTC
Prototype not loading in Google Chrome
Hi guys! I have a problem with my prototype in figma. I just open the prototype in figma and it works fine but when I open it in chrome it doesn’t load. This happens only in Chrome because I have opened it in other web browsers like edge and internet explore and it works perfectly. Can anybody help me?
May 20, 2022 2:30 AM UTC
I was able to fix it. For those who have the same problem, just go to the chrome url section and type chrome://flags and search for Choose ANGLE graphics backend and select OpenGL And it’s fixed.
Michael_Womack
Aug 13, 2022 7:08 PM UTC
I’d add one thing to the fine instructions in this thread about changing setting to OpenGL at “chrome://flags” address.
Initially, I only quit Chrome, and re-opened - to no avail. Use the “Relaunch” button that appears when you change the default value to OpenGL. Little detail - big, positive result!
Also note the granular detail regarding this Chrome setting. “Metal” value configuration is currently experimental and possibly (probably?) buggy, but config will replace the OpenGL config on Mac in the future when it is “fully released”.
So - be a bit forewarned!
Cassidy_Trier
Aug 15, 2022 8:53 PM UTC
This fix with the chrome://flags and OpenGL isn’t working for me. Is anyone else having this issue still?
Jeremy_Reither
Aug 16, 2022 2:01 PM UTC
Yes, still having the issue here as well. The solution described above didn’t work for me either.
Ioana_Ionescu
Aug 18, 2022 12:47 PM UTC
I still have this issue. The solution above didn’t work for me either 😦
Gareth_Davies
Sep 5, 2022 2:32 PM UTC
I have the same issue. The only workaround I’ve found is to load the prototype in an Incognito window, that seems to work for some reason.
James_Grogan
Sep 8, 2022 3:39 PM UTC
When I logged into Figma, it started working again for me. I did the OpenGL thing and it didn’t work for me.
Patbos
Sep 21, 2022 9:50 AM UTC
Multiple people around me are starting to experience the same thing.
Chrome as browser, incognito works fine, but not in normal mode.
tank666
Sep 21, 2022 10:41 AM UTC
@Gareth_Davies, @Patbos, if the prototype loads successfully in incognito mode, but fails to load in normal mode, then this may mean that the browser extensions that are enabled may affect the loading of the prototype. Go to the chrome://extensions page and try disabling all extensions.
Matthew_Pearson
Sep 23, 2022 8:48 AM UTC
I’ve been having the same problem and have disabled all my chrome extensions and it now works. I did disable all then close and reopen chrome. I tried with developer mode turn on and off in chrome extensions area. It worked with developer mode off and all extensions disabled.
In Safari and Firefox which I seldom use on my Mac it worked fine. I also works on a corporate Win machine running chrome and edge.
