Jennya_Rotman
Feb 2, 2023 2:32 PM UTC
Prototype is unclickable once overlay is on
Hello Community!
Im new in Figma and have a question.
I have an overlay that is triggered after delay.
The thing is that I still have interactions in this frame but the overlay “blocks” it, everything is unclickable at the prototype because of the overlay.
I know the other way to achieve this is to use the “duplicate screens” method, but I dont really want to do that.
Is there a way to fix this issue or do I have to do the “long way”
tank666
Feb 2, 2023 3:16 PM UTC
Instead of overlays and screen duplication, use interactive components.
Figma Help Center
AddWeb_Solution
Feb 9, 2023 1:15 PM UTC
  1. If the overlay is positioned on top of clickable elements then it will prevent the elements from being clicked. So please check that the clickable elements are above the other elements.
  2. You can also choose the option “Close when clicking outside” in the prototype settings so that overlay is closed when clicked outside and now the other elements will be clickable.
Andrew_Mckinley
Mar 8, 2023 6:58 PM UTC
How do I position clickable elements so they are above the overlay?
Markus_Beck
Jul 6, 2023 12:35 PM UTC
Figma writes:
an overlay is an interface element which appears avobe the main application interface.
so u can’t position over an overlay.
in our usecase we have some header which should be clickable, the overlay was manually positioned, the spaces for the header where there. but unfortunately the header isn’t working.
any help would be appriciated
Grace_Pinkstone
Jul 25, 2023 9:35 PM UTC
Hi, I am having the same issue. Were you able to figure it out?
Josh
Former Community Manager
Jul 25, 2023 9:45 PM UTC
Hi there @Grace_Pinkstone are you able to share a little more about what you’re trying to achieve. Overlays do in fact become the top-most element in a prototype which blocks all other elements from interactivity until the overlay is closed. You could potentially add the element directly to the overlay and have the interaction there but that may or may not be quite what you’re looking for.
Mark_Santos
Sep 30, 2024 9:12 PM UTC
Why is the overlay behaviour working like this? I can’t even think of a benefit of blocking the interaction underneath (main layer). What’s the workaround here?
Anna_Shchegoleva
Jan 28, 2025 12:58 PM UTC
The same here when overlay on (accordion element) all interaction from the page inactive!
EmberN
Feb 3, 2025 11:09 PM UTC
yes! also having problems here trying to do overlay but not interactive components. but that’s the constraint on a free account. you will need to buy it so you can use interactive components unfortunately for now. i only have free account for now while learning.
tank666
Feb 3, 2025 11:31 PM UTC
This is wrong. Interactive components are available on any plan, including the free one.
Please refer to the help article mentioned at the beginning of this thread.
