May 9, 2024 1:58 AM UTC
Prototype click not working for one component in hover nav menu
I’m creating a large prototype that involves a collapsable side bar nav. The side bar nav is pretty straight forward and expands when mouse enters, and when mouse leaves. I’ve made the nav bar a component with clickable menu items inside. These clickable items in the nav bar are components with hover effects.
All nav menu items work except 1, for some reason when clicked, just the hover state stays in effect and the ‘Navigate to’ doesn’t register.
Here is what that menu item looks like in the layers panel:
Not sure what else to do as I’ve changed the component name multiple times, deleted the interaction and re applied over and over again. All other menu items work except for this one.
Is this a bug? Do I have too many screens prototyped? Not sure what else to do.
May 9, 2024 2:01 AM UTC
I should note that it works just fine when I set the Nav Bar to the ‘Open State’ variant by default. However when defaulted to the "Collapsed’ state variant - I run into this issue
May 14, 2024 9:09 PM UTC
Hey @David_Blaisdell, thanks for reaching out and sorry for the delayed reply!
It’s hard to be sure what’s happening from your screenshot alone. Are you able to share a link to your file?
If so, please also share edit access with support-share@figma.com, so we can take a closer look.
jasperfernandez
Sep 2, 2024 12:12 AM UTC
I have the same issue
