Migo33
Dec 20, 2023 1:18 AM UTC
Missing fonts when I have all the fonts installed
I’ve seen other posts about this issue but nothing seems to help or work. I keep getting Missing font icon in the Figma app (not browser) for fonts I already use in other Figma files (that do not show the same missing font) and that I have installed on my Mac.
Also when opening the missing font dialogue window there is no option to ‘replace the fonts’. This is an example of a simple ‘Arial’ font which is installed and used across many apps on my Mac. It just says ‘close’ but no option to replace.
Thanks
Gayani_S
Dec 21, 2023 7:52 AM UTC
Hey Micha, generally if you’re seeing this warning for a system font, this indicates that the font stored on your system is different from the one used in your file, possibly because another editor has an older version installed (perhaps on Windows?), or the system font was recently updated. Manage conflicting fonts and Manage missing fonts cover these kinds of font versioning issues in more detail.
You ‘should’ be able to select the matching values in the Missing fonts modal to clear the issue. The desktop app cache could do the trick. Could you try clearing the cache by following these steps:
  1. Quit the Figma desktop app
  2. Open Terminal.app and enter the following command: rm -rf "$HOME/Library/Application Support/Figma/"{Desktop,DesktopProfile}
  3. Try opening the desktop app again
Celina
Mar 6, 2024 11:08 AM UTC
Hi there!
I’m having this same problem. I’ve installed new fonts and started a project - then, in the next day when I’ve opened Figma again I’ve got the missing fonts warning. Only me have access to the file.Even by reinstalling the fonts, closing Figma and reopening again, and even by clearing cache in terminal. Any idea what might be the issue?
Now, after this, I see the issue happening to all new fonts I have installed - I can’t see them in Figma.
Thanks!
Mar 7, 2024 2:30 PM UTC
Hey Celina,
Sorry to hear you are having issues, this looks odd! As you have installed the font on your computer and you are the only one who has access - or edit- to the file, you shouldn’t have the missing fonts warning. Can you also make sure either the Figma Daemon, Figma Font Helper, or Font Service is running on your computer’s activity monitor?
For more details about how to manage missing fonts, here is our article: https://help.figma.com/hc/en-us/articles/360039956994-Manage-missing-fonts
If this doesn’t help, I’d suggest you to reach out directly to the support team with a copy of your file: here
The support team can investigate it further. Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com so they can take a closer look. Thank you!
Jun 17, 2024 11:05 PM UTC
I was working in a few different files and Figma stopped pulling all my local fonts. Files are still on my computer. I didn’t do anything and it all of a sudden told me all my local fonts were gone in all my files.
I tried opening the terminal and using the command given above but that didn’t work.
@Celine_Figma
Jun 24, 2024 2:20 PM UTC
The same thing happened to me!!
I have installed fonts on my computer, they have been working just fine all year and now just today they are all missing. I think there is a bug on Figma’s end with their latest update. Please fix!!! this is not a user error and I cannot fix on my end.
Jun 24, 2024 5:46 PM UTC
Hey there! Thanks for flagging this, and sorry to hear this is happening.
It would be great to investigate directly with your file to see if we can replicate it.
As mentioned, if the workarounds don’t help, I’d like our support team to investigate it further to check the root cause on your end. Please reach out to them directly by filling this form: here
Be sure to use your Figma account email, mention the steps you did, include a link to the file, and share it with support-share@figma.com so they can take a closer look. Thanks!
Kellan
Jul 16, 2024 3:18 PM UTC
What worked for me was installing the fonts so that they show up under “All User Fonts” on Mac’s Font Book–as opposed to just in “My Fonts” or “All Fonts”. After you do this, restart Figma. Copy pasted method via ChatGPT:
To make fonts available to all users on a Mac, you’ll need to install them into the /Library/Fonts directory. Here’s how you can do it:
  1. Find the Fonts: Locate the font files you want to install. These are usually .ttf or .otf files.
  2. Open Finder: Click on Finder in your dock to open a new Finder window.
  3. Go to the Folder: In the Finder menu at the top of the screen, click on Go and then Go to Folder....
  4. Type the Path: Enter /Library/Fonts into the window that pops up and hit Enter. This will take you to the system-wide Fonts folder.
  5. Install the Fonts: Drag and drop your font files from where they are currently saved into the /Library/Fonts folder.
By placing fonts in this folder, they will be accessible to all user accounts on your Mac. If you don’t have the necessary permissions to add fonts to this folder, you may be prompted to authenticate as an administrator.
Oren_Savidor
Jul 29, 2024 9:48 AM UTC
I’m having the exact same issue as Celina was describing.
Any idea how to solve this?
Jul 29, 2024 10:43 AM UTC
Hey @Oren_Savidor , sorry to hear you are also having issues.
This article has some workarounds to manage your missing fonts, please have a look at it first:
Figma Learn - Help Center
And, if this doesn’t help, the best option will be to reach out directly to the support team so they can investigate further the root cause on your end here
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com so they can take a closer look 🙂
AlexisM
Aug 5, 2024 12:32 AM UTC
Hey all, so after having this same issue for a while, I reached out to Figma’s support and Nancy quickly followed up with me and sent me a few solutions.
The solution that worked for me was to right click on the font, click “Show more options” and click “Install for all users” (if Windows 10, skip the “Show more options” part)
