PartyParrotGreg
Feb 28, 2022 9:44 AM UTC
Long loading times for Swap Instance panel
Hey, I noticed that the Swap Instance panel in the Design tab takes a lot of time to load. No matter the internet connection (slow or fast) this take ages. Sometimes I need to restart Figma in order to make it work.
Some of the libraries, like this one: Phosphor Icons added to the Community, has more than 4,000 components
Not sure what is the technical strategy for serving components from the libraries but this is really slowing down my workflow (alongside the new, and messed up, way of not look-up for components among all the libraries).
Hiroko
Apr 21, 2022 10:28 PM UTC
Ys, same issue here too
Hiroko
Apr 21, 2022 10:59 PM UTC
I just closed Figma, and re-opened. Solved issue and able to load swap instance panel without delay.
Yuqi
Apr 24, 2022 6:34 AM UTC
same issue. solved this by using figma in the browser.
Reopening the Figma desktop does not work.
seems Figma desktop has an unstable connection?
anastako.design
May 19, 2022 11:20 AM UTC
Same issue here! Loads indefinitely even on local components
Andre_Cassal
May 23, 2022 7:27 PM UTC
any solution found here?
Hanan
May 25, 2022 4:22 AM UTC
Hi everyone, this started suddenly for me and I can’t get the instance list to load no matter what I do on desktop app or the browser. Any help would be appreciated.
Hanan
May 25, 2022 4:34 AM UTC
Hi so I finally found a way around this by trial and error, I detached a copy of any component that has a swap instance property for a nested component. Then I tried loading the instance list for the component nested within the component we just detached and it worked. After that, the issue was resolved for nested components without the need to detach anything. Seems like the issue was to just get it to load once.
Patrick21
May 25, 2022 9:17 AM UTC
Thanks @Hanan for the interesting discovery. Hopefully, it will help Figma find and fix the issue.
@Hiroko , I’ve also experienced just closing Figma Desktop and opening it again solves the issue for a day or two…
Prazak_Dawid
May 30, 2022 8:18 AM UTC
Can this be investigated officially please? Im experiencing this issue quite frequently.
Sangpil_Hwang
Jun 2, 2022 1:40 AM UTC
I have same issue. Is there any way to handle this problem?
