lenny1
Aug 30, 2024 8:46 PM UTC
Issues with Imported SVG from Canva: Incomplete Circles and Color Filling
Hi everyone,
I’m new to Figma and I’m encountering a problem with an SVG file I imported from Canva. Some of the circles in my project appear to be cut off and are no longer complete circles. Although Figma recognizes these shapes as circles, I’m unable to fill in the missing parts with color.
Interestingly, some of the circles are displayed correctly and are complete.
Here’s what I’m seeing:
  1. This is how some of the circles look in Figma.
  2. Here you can see Figma recognizes the circles.
Does anyone know how I can fix this issue or work around it? Any advice would be greatly appreciated!
Thanks in advance!
Eldurini
ElduriniSolution
Aug 31, 2024 4:24 AM UTC
Hi @lenny1
It seems that some circles are cropped within the group borders. It would be really helpful if you shared a link with the same icons that I could look at.
For instance, you can turn this “Group” into a “Frame”, just click on the “Group” option on the top of the right side panel, and change it to “Frame”.
After doing this, remove the option “Clip Content” that will appear in the “Frame” section.
Also, you can try to detach the components, and explode all frames/groups until you have clean SVG, or just select the desired part of the SVG and copy it outside the frames/groups.
Good luck.
Eldurini
ElduriniSolution
Hi @lenny1
Good luck.
lenny1
lenny1Author
Sep 2, 2024 12:11 AM UTC
Hi @Eldurini
Thank you so much for your help! I followed your advice and turned the “Group” into a “Frame.” However, I found that I needed to keep “Clip Content” enabled for the circles to display correctly.
After making this change, the problem was solved, and the circles are now showing up as expected.
Thanks again for your guidance - I really appreciate it!
