sekeidesign
Apr 7, 2021 2:53 PM UTC
Is there any way to change the "z-index" of an auto-layout child?
I’m using auto-layout for this modal, just like I do for pretty much everything else, and I’m creating a modal, with a text field, and a dropdown.
The dropdown should float above the buttons, and I’d prefer to do this with auto-layout. (I know I could use an overlay, it would be nice to control the z-index somehow though)
Slava_Bronevitskiy
Aug 20, 2022 8:30 AM UTC
And now add a dropdown component where options open downwards, with tooltip flying upwards, and you are back to the frustration land.
This stacking order does not fill the need for z-index
impactby.design?ref=nI
Simon_Steer
Aug 31, 2022 4:13 PM UTC
Not sure if I understand your specific case correctly, but do you mean something like this?
I was able to achieve this without modifying any auto-layout child’s z-index. The Figma file is public so if you want to see how everything is set up you can do so here:
Figma – 31 Aug 22
Slava_Bronevitskiy
Sep 1, 2022 8:44 AM UTC
This is the case
Simon_Steer
Sep 1, 2022 3:56 PM UTC
I see. You can still achieve this effect with auto layout and reversing the stacking order of items, but you will have to reorganize how your UI is built somewhat.
Instead of having a single vertical auto layout and several rows, you will want to have a vertical auto layout for each column’s rows (ID/Risk/Status). You can then set the stacking order for the Risk column to “First on top”, and the stacking order for the Status row to “Last on top”.
I updated the file I shared earlier with this prototype, so feel free to take a look at it to see how I’ve set it up. Maybe not the cleanest solution, but it will do what you need.
Slava_Bronevitskiy
Sep 2, 2022 1:17 PM UTC
Hi Simon. I appreciate you going new lengths to workaround the lack of adjustable z-index mechanism and recreating the scenario.
You solved the problem locally. There are many other creative ways to solve this locally. Like rendering tooltips as overlays for example.
You changed the layer structure from row-based to column-based. This allowed you to have up and down flyouts to display correctly, but broke row hover possibility, cell stretching when one of the cells has multi-row content and will still have the same z-index issue for everything extending left and right. So you basically rotated the problem from vertical plane to the horizontal, creating additional non-z-index related errors.
Without z-index properly implemented by Figma, workarounds will always be solved in one place, but always break in another.
We have a modular (cell content, cell, row, grid) data grid component in our design system, used across an enterprise application landscape. And data grid is just one of many components affected by the lack of z-index. Others are lists, selectors, search forms and more.
Patching all instances locally is a seriously bad decision because of the scale. It will require design maintenance effort that is larger than the benefits it returns. We are better off calling front-end developers when they are about to develop the UI to explain things verbally, or creating a throw-away screenshots.
Although your help effort is appreciated, this is not an issue a community member can help resolve. This is a request to Figma dev team for an irreplaceable functionality. Unfortunately Figma is not hurrying.
Lucien
Oct 12, 2022 6:24 PM UTC
The “canvas stacking” option solved the issue for me! Thanks Simon.
Sudarshan_Mane
Dec 23, 2022 3:45 PM UTC
You Are Real Hero!
Tiffany_Loue
Jun 15, 2023 2:56 PM UTC
You are my hero for today ! 👏🏼
Paul_Lyons
Oct 5, 2023 9:11 AM UTC
Agree 100% @Slava_Bronevitskiy.
Any news Figma Support?
Is this in the pipeline as a future feature?
Ivan_Bravo
Oct 21, 2023 7:40 AM UTC
Just use absolute position instead auto-layout on the faulty component.
