Apr 16, 2024 1:46 PM UTC
Is it possible to remove Dev Mode annotations?
I’m trying to copy/reuse some components that have Dev Mode annotations, but I want to reuse them to create another type of component, so the current annotations don’t really match the new component and I would just like to remove all annotations all together, but couldn’t find how to do it yet.
Is it even possible? If so, how can I do that? 🥸
ksn
Apr 18, 2024 4:57 PM UTC
Hey @Benilio! Yes, you can delete/remove annotations – see here.
Just one note: you need to have a full design seat in order to edit any annotations, so if you have a Dev Mode seat, you’ll only be able to view.
Siddhant_Modi
Aug 28, 2024 12:27 PM UTC
Looking for solution to the same problem. Let me try and explain it in a bit more detail.
Annotations get copied when I copy a frame. If the original frame has 10 annotations, the copy also has the same 10 annotations, whether I want them or not. I am looking for a way to delete all the annotations together, without having to do it one by one.
Userinterfacer
Feb 12, 2025 3:48 PM UTC
This is critically missing feature to remove all annotations or to paste without annotations. You simply do not want to always copy the annotations when copying a frame, e.g. when you’re creating variants or new views based on the original. I think the most elegant way would be to add the action “Remove all annotations” for selected Frame to the top Edit menu.
Julia57
Mar 3, 2025 10:27 AM UTC
Agree…. I removed the annotations from my master component and republished it, but this still didnt remove the hundreds of annotations on my other instances. I even copied one instance that didnt have ay annotations, and then paste-to-replaced all the others, but the annotations were still there.
