Hi,
I chose the iPhone 14 Pro Max frame. However, when the prototype only shows a rectangle frame and not the iPhone design frame. Is something I’m doing wrong here?
Hi @Nirav_Gajjar ,
    1. Open the Prototype tab in the right sidebar
    1. Click in the button “Show prototype settings”
    1. Select the device you want (here, iPhone 11 Pro Max)
    1. Then, you can see the iPhone design frame in the presentation view!
I am having this issue as well where I can not get it to display. I also notice your menu has Inspect and mine does not. Could that be the issue?
2 posts were split to a new topic: Allow designing from within device frame
A post was merged into an existing topic: Allow designing from within device frame
