Elkin_Tat
Oct 11, 2024 4:47 AM UTC
How to make a frame grow with text?
I have a a text box within a frame that has a top and bottom border, like this:
When I add more text to the text box, I’d like the frame to expand to accommodate it, but I can’t seem to get the outer frame to change:
What I want to happen is for the frame to expand like this:
Any suggestions?
adTHANKSvance!
Anais_Ferreira
Oct 11, 2024 6:50 AM UTC
Hello!
The Auto Layout function can help you.
Simply apply an auto layout to your frame (Shift+A or right-click on your frame and select “Add auto layout”) then, constrain its height according to its content, by applying the “Hug contents” mode in the right-hand side menu.
For more information, take a look at the auto layout tutorial and the object resizing tutorial
I hope it’ll help you 🙂
Ravi_Madhusanka
Oct 11, 2024 7:00 AM UTC
  • Select the frame and press Shift + A to add auto layout.
  • In the auto layout settings, set the width to fixed and height to hug contents. Add padding as needed.
  • Select the text layer inside the frame and set its width to fill container.
This will make the frame expand as the text grows, but keep its width fixed as desired.
Elkin_Tat
Elkin_TatAuthor
Oct 11, 2024 4:30 PM UTC
Thanks, Anais and Ravi, I’ve been able to make an expanding frame!
Follow-up question: Currently the frame I’ve made only expands in the downward direction as text is added. Is there a way to make it expand both up & down, so the frame stays centered vertically?
