Hi!
I created a dropdown menu component with two variants (collapsed and expanded). I set the interactions to where when you tap on one of the items in the expanded list, it will set the default text variable displayed to the text for the selected item and change the state back to the collapsed menu.
I have instances of the dropdown menu component on several different frames, but when I enter prototype mode if I select an item on one frame from the dropdown menu, when I go to another frame that item text is already displayed in collapsed dropdown menu instead of the default text.
For example, if I go to customize an item the first time the dropdown menu displays “select option” and I can choose the option “wheat bread” and it will display “wheat bread”, but when I go to a different frame to customize a different option it will already be displaying “wheat bread” instead of displaying the default “select option”.
Anyone know how to fix this?
