joshmillgate
May 31, 2022 3:48 PM UTC
How to delete a variant property
I simply want to delete the property “Label Size” on all my variants. I could do this by renaming the layers and removing “Label Size=Sm” but I have hundreds of variants and that would take forever… I can’t right click on the property anywhere.
CleanShot 2022-05-31 at 16.47.11
tank666
May 31, 2022 3:56 PM UTC
First select the Component Set and then:
joshmillgate
May 31, 2022 3:59 PM UTC
Ah! Have to select the set, thanks!!
Alec2
Jul 21, 2022 1:36 PM UTC
Hi ! the solution don’t work for me : I select the the component set (“edit_info_layer”) which is composed of two variants with a single property (“SCOPE”). In the Properties parameters panel, no option will pop on a right-click. When hovering the property name, the edition icon is display and it only allows to rename or target the variant with each value.
Capture d’écran 2022-07-21 à 15.33.44
Any clue will be welcome 🙏
Thanx,
Alec
tank666
Jul 21, 2022 2:28 PM UTC
What do you want to do?
Alec2
Jul 21, 2022 2:44 PM UTC
Delete the property " SCOPE "
tank666
Jul 21, 2022 2:51 PM UTC
It is not possible to create Variants in a Component Set without properties, or delete a single property. If you don’t need properties, then don’t combine components as variants. And if already combined, then:
Alec2
Jul 25, 2022 1:58 PM UTC
  1. Select all variants and drag outside the purple border.
Works great and simple as " Bonjour ". Thank you so much 🙏
Rob28
Oct 4, 2022 10:23 AM UTC
This is great, but is there a way to do this without losing the component description?
tank666
Oct 4, 2022 10:48 AM UTC
Which layer (object) has a description added to? To a Component Set or Variant within a Component Set?
If to Variant, then the description should remain.
Rob28
Oct 4, 2022 11:35 AM UTC
I understand. Unfortunately, the description is added to the component set.
To give you more context, I’m talking about the official Material Design Icons library. I was trying to extract one style but keep the description tags from the component set for better search results.
Thank you for your time!
