Lezhang
Aug 2, 2022 6:09 PM UTC
Help. Trying to stretch the frame only but other components are stretched with it
When I try to stretch the frame, other components are also stretched, as you can see in my screen shots. I only want to edit the frame. How can I do it?
tank666
Aug 3, 2022 11:00 AM UTC
Set the correct constraints and resize the frames. Or:
Lezhang
LezhangAuthor
Aug 3, 2022 6:12 PM UTC
I figured it out, thank you so much!
Jesuferanmi
Nov 4, 2022 8:10 AM UTC
This worked! Thank you.
Feb 28, 2023 6:42 PM UTC
This worked for me too! Thanks!
Feb 5, 2024 10:13 AM UTC
Thanks, it helped
Gary_Mcbilly
Sep 19, 2024 10:13 PM UTC
I want to resize the frame because I realized I have to add more items below. But I do not want anything I have already designed to move. However, when I try to add to increase the frame height then everything starts to move on the frame. So I stopped and I am trying to rebuild the whole frame. However I am sure that there is a solution for this. Kindly help!
221B
Feb 15, 2025 5:13 AM UTC
Thanks it works. Just hold ctrl and drag!
kilu
Mar 11, 2025 6:59 AM UTC
Thank you. It works!!!
kmart
Apr 22, 2025 5:26 PM UTC
Do you want to resize the frame ignoring the constraints? Hold Cmd/Ctrl and drag the border of the frame.
two years after: this helped me!! Thanks
