Regi
May 17, 2022 1:21 PM UTC
Gradient fill angle
Hi, I’m seeing an angle on gradient fill, even though I should not. Is it something I’m doing wrong or a bug?
Thanks!
j.au
May 28, 2024 11:28 PM UTC
I’ve just discovered this bug with gradient in my design system and it’s super annnoyyyingg… 😦
Ian_Grossberg
Jun 12, 2024 4:01 AM UTC
I’ve recorded a video example, but I am a “new user” and cannot attach files apparently. I’ve uploaded the vid here: https://youtu.be/E7ThbX_F8rM
Jun 25, 2024 3:59 AM UTC
Hello, thank you for sharing the video with us. I’m unsure, but it may be related to our feature limitations. Would you kindly take a look at this post for a workaround?
If this does not align with the post above and you believe the tools are not functioning as expected, it would greatly help if you could fill out a bug report directly from here:https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
Pease remember to include the following information so that we can take a closer look:
  • Use your Figma account Email.
  • Add support-share@figma.com as an Editor to the affected file and any related library files (this will not affect your billing) and provide those direct links.
  • Please share a recording demonstrating the issue you are facing. Make sure to include the whole window, with the properties and layers panels visible. Expand the relevant layer and select the layers you are having trouble with.
Thanks for your understanding and support!
